4.0 Ranger - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
Old 04-08-2010, 10:02 AM
4.0 Ranger
My buddy's 96 Ranger with 4.0 v6 with 160k does strange things when he starts it up. He'll start it and it used to rev up a little bit until it was warmed up then slow back down. Now he'll start it and it will try to die then he'll give it lil gas and then it will straighten up and run just fine. Any ideas?
Old 04-08-2010, 10:09 AM
IAC most likely. Replaced hundreds of them
Old 04-08-2010, 10:17 AM
Thanks, we'll check it out
Old 04-08-2010, 10:21 AM
I found an write up on an explorer forum about how to clean the IAC. Could we get by with this?
IAC valve cleaning thread (w/pics) - Ford Explorer Ranger Enthusiasts "Serious Explorations"®
Old 04-08-2010, 10:29 AM
You can try it but in my experience that never worked. It was always the motor that was bad. You can pull it off and start the truck or just turn the key on and off and if it doesn't move in and out very quickly it's not working and cleaning most likely won't help.
Old 04-08-2010, 10:33 AM
Alrighty, we'll try it and see what happens then go from there. Thanks
Old 04-08-2010, 10:35 AM
Slacker
Feedback Score: 4 reviews
Check the IAC; if it's good, replace the MAF sensor.
Old 04-08-2010, 10:53 AM
Thanks, We'll check it out. Btw it's not throwing a CEL so
Old 04-08-2010, 10:54 AM
They don't always throw a code for the IAC
Old 04-08-2010, 10:56 AM
That's good to know. We're gonna work on it after he gets out of class here pretty soon.
