| Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!! |
86 302 info needed asap
Ok, not a huge ford gas guy, but does anyone know if the fuel injection setup from an 86 ford 302 will just bolt onto a carbed 302. the fuel injected motor had knock and i can get the carbed motor for 400 bucks complete. Is it just swapping parts? Thanks guys
If your woundering if you can use the Carbed engine and swap your fuel injection parts over to it then yes you can. It will bolt up
what year is the carb'd engine from?
doesnt say what year. did they change anything significant over the years? both are ford 302s, just ones a 2bbl carb unknown year, the other is 86 fuel injected
Just put swap you EFI intake and valve covers on to the carb engine and your set.
thanks a ton. doin a swap for a family friend and trying to save him on parts. rod knock eats cranks every time, rather not chance anything
