super chips flash paq or superlift truspeed - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
Old 12-29-2009, 12:31 PM
does anyone have any experience with either of these? my sister has an 01 f150 with a 5.4 in it. with her lift and tires her speedo is off by about 12 miles per hour. i dont know much about either of these except that i think the truspeed taps into the abs and you have to calibrate it yourself and the tire paq plugs into the obd and can be used a chip as well if upgraded. any info or experiences with either would be great.
Old 01-04-2010, 04:27 PM
Are you going for performance and correct speed or just correct speed?
Old 01-04-2010, 05:29 PM
mainly to correct the speedo, but if the flash paq has the tire paq for not much more then i wudnt mind going for both
Old 01-04-2010, 05:33 PM
I had the superchip on my old 5.4 and the speedo was still off . My son has one on his 5.4 speedo is off. I'd go true speed ..
Old 01-04-2010, 05:38 PM
thanks mike. good to know. ill probably go a different route then that one then
Old 01-04-2010, 05:42 PM
My truck was a 2004 and my sons truck is a F150 2000 5.4 sorry didn't mention this before.
Old 01-04-2010, 05:46 PM
no prob. my sisters is an 01. so probably pretty similar. her's has 33's on it
Old 01-04-2010, 05:49 PM
Yeah I had 35's and my son has 33 now as well.. Good luck
Old 01-06-2010, 01:15 PM
One of my friends has the superships on his 5.4 and doesn't really care for it. Tire size vs. speed still not dead on and the performance not great. Would not recommend it.
