Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Ford Gassers
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
Old 10-06-2009, 07:33 AM
my19997.3 my19997.3 is offline
'78 F150 Leaf Spring Question
Has anyone here replaced or upgraded their leaf springs? I'm trying to find out 1) how hard it is to add a single leaf to the cluster and 2) how hard it is to remove the old cluster and add a new cluster. Does anyone have any tips or a write-up? As always... THANKS!
Old 10-13-2009, 10:06 PM
Dusten Dusten is offline
Send a message via MSN to Dusten
im assuming you are talking about an add a leaf. Its fairly straight forward. you'll need the new leaf and a longer center pin. remove the old center pin(vice grips and wrench, or maybe a torch) the leave pack should come apart. install the new leaf where it goes in the leaf pack. you can use a c-clamp to compress the leaf pack. install the new center pin.
