Turning the air/heat on. Help - Ford Powerstroke Diesel Forum
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
Old 10-05-2009, 04:20 AM
Arrow Turning the air/heat on. Help
I know this is mainly a diesel site, but I figured a problem like this could be solved by any mechanic. My girl has a 1995 Grand Marquee and when she turns the air/heat on it only works on high and sounds like something wants to come apart. LIke a really bad hum that has got worse. I've changed the switch and nothing changed. Any info would be great!
Old 10-05-2009, 04:26 AM
I am that hot
bloooower motor resistor, just did one in a friends focus
Old 10-05-2009, 04:29 AM
Hmm have any idea where that may be located? Im a learner lol
Old 10-05-2009, 04:39 AM
I am that hot
Look under the dash on the passengar side.. Ill try and find a pic
Old 10-05-2009, 04:40 AM
I am that hot
Ford Blower Motor Resistor Pigtail Replacement
Old 10-05-2009, 04:41 AM
Send a message via AIM to nccatfan
Follow the harness back from the blower motor... first thing you come to should be the resistor module.
Thanks a lot man i'll look into it. You dont think it could be the blower?
Old 10-05-2009, 04:42 AM
I am that hot
not usually, speeds have to do with the resister module
Old 10-05-2009, 04:44 AM
Hmm it looks like all I do is get the new part and splice it in?
