Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Ford Gassers
Ford Gassers A Place for Diesel nuts to discuss Ford Gasoline powered vehicles!!!
Old 02-07-2007, 08:34 PM
polarisfan polarisfan is offline
Everyday/Muddin truck
i was wondering what i should do to say a late 70s to late 90s Ford 150 or 250 to make it a good mudding truck but still make it a decent daily driver. any help is appreciated.
Old 02-07-2007, 08:46 PM
Big Tone Big Tone is offline
Your gonna have to make up your mind witch one you want, A mudding truck, or a decent daily driver!
Old 02-07-2007, 08:48 PM
owtcast owtcast is offline
I second that. The more off-road capable you make a vehicle, the worse it is for a daily driver. I say this because I have experience with that same scenario.
Old 02-07-2007, 09:50 PM
straycat straycat is offline
I third that, are you after a driver that you can hobby mud with or a serious mud truck you can drive home?--- Bet you thought you were asking a easy question.hahaha.
Gord.
Old 02-07-2007, 09:59 PM
lilredpowerstroke lilredpowerstroke is offline
Dont listen to them build what ever you want. :nono:Mines a daily driver and it pulls sleds and plays in the mud with the best of them. I would go with the 250 since the parts are stouter than the 150.
Old 02-07-2007, 10:06 PM
dustindiesel dustindiesel is offline
u can prob do both..just be prepared to be able to fix it and have parts readily available.def go with a decent lift to clear bigger tires and that isnt unsafe for road driving either..superlift makes some nice ones.u can also cut up dem fenders to give u clearence.id go with the 73-79 f250.easy to work on and good on a budget.find parts for them everywhere
Old 02-08-2007, 02:23 PM
this is like the truck i want to turn it into. what do you suggest i would all need?
Old 02-08-2007, 02:29 PM
That trucks to slick to take in the mud!
Old 02-08-2007, 02:33 PM
Powerstrokin' Powerstrokin' is offline
I would say... and then some!!! Nice truck polaris.
Rob
Old 02-08-2007, 03:39 PM
pipelayerjdh pipelayerjdh is offline
MINI-MOD
I know a guy that ran 39.5's on a stock '77 f-250. He just cut the fenders a little. It had a stock 351 M with a good cam and a 4spd. It was one of the baddest mud trucks I've seen. The holy grail of mudders is a late '70's f-350. They are unstopable. go with the 351 M, parts are cheaper than a 460 and they are easier to find. They are also very tough engines with great low end power from the factory. Just throw on a performer 4 BBL intake and Holley 650 or 750 if you add a good cam.
Running gear on any of the '70's trucks are very reliable. Lifts are cheaper and you get a solid front axle unlike '80's and '90's model trucks. With the f-150 you get a Dana 44 front and 9" rear, both easily repaired and cheap. F-250's have Dana 44 fronts and Dana 60 rears witch are alot tougher, but more expensive to build. F-350's had Dana 60 front and rears.
If you want a mudder, I suggest a long bed truck.
