New barrel for my Remington 870 for deer season - Ford Powerstroke Diesel Forum
Firearms Discussion Discussion of all types of firearms.
post #1 of 37 Old 09-30-2013, 08:31 PM Thread Starter
usteffenhagen's Avatar
I usually use my .243 for deer, but being in Virginia now makes me think I should invest in a different strategy. My current shotgun set up is a Rem. 870 18" barrel. TAPCO 6 position adjustable butt stock. I still have the original stock but I would like a longer maybe 28" barrel also rifled for range/ accuracy. Anyone know where would be the best place to look/ brand names for a new barrel?
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #2 of 37 Old 09-30-2013, 08:56 PM
fordpwrstroke7's Avatar
Why change from the .243? I'm not familiar with the rules in your state but I would stick with the .243 or .270 (head shots are perfect for does).
2008 F-350 CCLB
2004 F-250 CCSB (sold)
1997 F-250 CCSB (sold)
1994 F-250 ECLB (sold)
fordpwrstroke7 is offline
post #3 of 37 Old 09-30-2013, 09:36 PM Thread Starter
I agree 100%. The main reason is to hunt on base. There is a SEVERE deer population and on base it's either bow, muzzle loader or shotgun and because of my location, I would have to drive about 30 mins south to get into some good areas. And a problem here is that there is so much private land, any open areas are riddled with other hunters. So I've been told anyway. It's my first season here.
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #4 of 37 Old 10-01-2013, 06:35 AM
Bad Mojo's Avatar
I would use the shotgun exactly as its currently set up.
Bad Mojo is offline
post #5 of 37 Old 10-01-2013, 09:02 AM Thread Starter
For deer hunting? The short barrel wouldn't have the range or accuracy though. I'd think anyway.
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #6 of 37 Old 10-01-2013, 09:17 AM
Bad Mojo's Avatar
Its a shotgun, a short range weapon by design. You can throw whatever barrel you want on it, you'll very rarely get rifle-like accuracy out of a factory, pump shotgun. Short, stiff barrels are generally more accurate than long barrels anyway. Its all moot if you plan on using buckshot, and only slightly less moot if you'll be shooting slugs. Don't overthink it. Use what you're comfortable with, and learn as you go.
Bad Mojo is offline
post #7 of 37 Old 10-01-2013, 11:28 AM
I_AM_RP3's Avatar
I hunt in VA too and have used shotguns my whole life. A longer barrel is a must. 26" or 28". With an 18" barrel and buck shot you will have a pattern the size of a house at 50yds. If you do plan to use buckshot, I wouldn't use a rifled barrel as it will throw pellets everywhere. A Remington barrel with a full or extra full choke will work perfect for 00 buck out to 60yds and sometimes 70 if the conditions are right.
Sent from my DROID RAZR
I_AM_RP3 is offline
post #8 of 37 Old 10-01-2013, 11:59 AM
Bad Mojo's Avatar
This isn't entirely accurate. The choke has more to do with shot pattern than barrel length. The amount of tube between the forcing cone and the choke doesn't change anything, for better or worse. These are all generalities, though. There can be drastic differences between two seemingly identical guns. Take your gun out and see how it patterns, then decide if a new barrel is actually needed.
Bad Mojo is offline
post #9 of 37 Old 10-01-2013, 02:07 PM Thread Starter
No matter what I would be using slugs. I just figured a short barrel like mine wouldn't be as accurate... Not that I'm anticipating any 100 yd shots over here though
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #10 of 37 Old 10-01-2013, 02:34 PM
Bad Mojo's Avatar
You absolutely do not need a longer barrel for slugs. Does your current barrel have sights or a bead? Its hard to be accurate shooting rifled slugs out of a smooth bore with just a bead sight.
Bad Mojo is offline
