| Firearms Discussion Discussion of all types of firearms. |
Question on the spent shells
not worried or anything but the scuff on the end of the shell, its always just that one spot and all of them have it. Is this just the result of the shell being ejected from the chamber?
I believe that is a "ring" from which the bottom of the bullet is seeded. The pressure causes the case to expand and it stops where the bullet starts....if that makes sense
Have you chambered a round and then ejected it without firing? Do you see the same mark on it? The reason I ask, is it could be related to the chambering of the round into the barrel. Also check the round as you load the clip too. There are several different places that could come from.
Ok i did that and im now getting the scratch marks from the top of the shell to the bottom. just a line. but the scuff above doesnt happen execpt when firing.
Looks like a "normal" spent Glock case to me. swelled case base. scratched up neck. I bet the primers have a smiley on em too. :-D
