Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Off-Topic > FABRICATION FORUM
FABRICATION FORUM Let's see your ideas and work! :)
Old 06-11-2009, 10:41 AM
metallitera metallitera is offline
best way to protect wood?
my new to me trailer has a home made rear ramp door. they made a metal frame and put 2 like 3"x6" sheets of plywood, i think its marine grade. looks to have a plastic venier on it. anyhow, one side is rotting out and i wanna replace and have it stay a while.
what should i treat it with? i looked at thompsons water seal, polyeurathane coatings, and that epoxy garage floor paint. what would work best?
Old 06-11-2009, 10:49 AM
TWhaylen TWhaylen is offline
If I were you I might consider spraying the new lumber with Herculiner! That would be very durable and would last quite a long time. I actually have an ATV trailer that is all wood on the flooring and am thinking about doing this with those planks so they remain protected for a long period of time. Not to mention that it would add extra traction on that ramp for whatever you might load up onto the trailer.
Old 06-11-2009, 11:00 AM
drstephennix drstephennix is offline
LSP Director
Send a message via Yahoo to drstephennix
poly coatings works great too
Old 06-11-2009, 11:04 AM
03-blue-Powerstroke 03-blue-Powerstroke is offline
Go Mark Martin!!
I stained my trailer deck with Cabot natural sealer. Its the same stuff that you would use on your deck. I think its like $30.00 a gallon but it has stood up to the abuse and weather. I gave it two thick coats and the wood still looks brand new 2 years later.
Old 07-29-2009, 05:38 PM
horsepoor68 horsepoor68 is offline
I was tought by an oldtimer to treat my tailers with linsead oil and thiner. 50/50 mix. Cheapest you can find. Do it on a hot day works best. I use a bug sprayer to apply or you can use a paint roller. With a 2 gallon mix i treat my goosneck flatbed and quad trailer once a year. Just let it sit a few days to dry. My trailers sit out in the AZ sun year round no cracked or rotten boards after 5 years.
Old 07-30-2009, 09:40 AM
linseed oil = spontaneous combustion.
i don't need my trailer ending up like one meridian plaza LOL
