Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Off-Topic > FABRICATION FORUM
FABRICATION FORUM Let's see your ideas and work! :)
Old 04-28-2009, 09:39 PM
metallitera metallitera is online now
Cool Making a trailer out of a cargo van box
So I found this on e-bay this and got out bid. Well it got me thinkin, since all the 24' trailers ive found are in crappy horrible condition in my price range. (around $2000).
If i could get me a box like that one, I could make that trailer for fairly cheap I think.
Im wanting to know if the price i got on 8" C channel was bad. $120.75 per 20' section. Figure I'd need 3. and I found some weld on, heavy duty 2-5/16" ball couplers, and a 6k# axle with brakes for $600.
I was also thinking of getting a box with an attic and making it into a goose neck?
what ya'll think?
Old 04-30-2009, 06:06 PM
kingchip kingchip is offline
I'll sell you my 40' dual 10K tandem trailer that needs wood and tires for $1200. Lots easier. I just don't use it, and it sits at the ranch. I drilled ratholes about 15 years ago and needed it to haul a 20" X 40' piece of pipe.
Old 04-30-2009, 06:18 PM
RRonning1984 RRonning1984 is offline
Heavy Equipment 911
You think a 6k will be enough?
Old 04-30-2009, 07:15 PM
I would prefer a dual axle set up with that heighth. Two 3500's or something like that. But with the weight of the box, you are limiting what you can haul in it legally. The box and steel that you describe combined weight has to be pushing 3K empty.
Old 05-11-2009, 07:29 PM
ok, so back to making the trailer idea. if i use a cargo truck and just whack off the front frame and throw a tounge or gooseneck setup on the front.........think i cab fab the hydraulic brakes to work with a surge brake system (tounge only obviously), OR get some electric brakes that will bolt to the axle in place of the truck's hydraulic brakes withOUT mods like welding on the back plate etc? just bolt up to the axle flange?
Old 05-11-2009, 07:32 PM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
Sounds heavy, which in turn means your load capacity low because the trailer will be heavy.
Old 05-11-2009, 07:45 PM
StarDriver StarDriver is offline
By the time you get done trying to fab up everything, you can buy a decent used trailer.
Look on For Sale: race & performance cars, engines, engine parts, trailers, you can buy new 24ft trailers for around $4,000-$4,500.
If your still considering this, here are a few things to keep in mind. I wouldn't own a trailer to haul a car unless it had at LEAST 5200# axles, plus this get's you the bigger tire which will ride better. A 24 ft enclosed is going to weigh around 4000#s empty, if you put a 3500# car with 2 3500# axles, your already overloaded.
Old 05-11-2009, 07:59 PM
02lariat7.3 02lariat7.3 is offline
Send a message via AIM to 02lariat7.3
kingchip, if metallitera isnt interested could you send me some pics of the trailer? thanks!
Old 05-11-2009, 09:27 PM
all this load talk. im not carrying a large load, mainly need the space. will the truck axles work?
