Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Off-Topic > FABRICATION FORUM
FABRICATION FORUM Let's see your ideas and work! :)
Old 04-27-2009, 10:37 AM
tfloyd22091 tfloyd22091 is offline
headache rack
i bought a ranch hand style hauler headache rack with bed rails does anyone know the best way to bolt it on to the bed.
Old 04-27-2009, 10:41 AM
gabelnj gabelnj is offline
how much did the rack run you?
Old 04-27-2009, 10:43 AM
mudrunninpig mudrunninpig is offline
D80 Axle Snapper
didn't it come with directions??
Old 04-27-2009, 10:47 AM
wriott wriott is offline
BUILT & BROKE BY ME
some styles clamp to the top rail and some have to be bolted (some bolt to the top and some to the bottom of the rail).
x2 on the directions
Old 04-27-2009, 11:03 AM
it was 325$ on craiglsist so it did not come with directions. the thing i am worried about is where to bolt it and were to hook up the wires. should i just figure out which wire is the brake and which one is the back up and splice them with the ones under the bed going to the back already ??
Old 04-27-2009, 11:11 AM
lsmith33 lsmith33 is offline
Send a message via AIM to lsmith33
i have one too. use 1/2 in bolts and bolt them on the side of the rails. if u do it like that the top of ur plastic wont be torn up
BUILT & BROKE BY ME
if it were me i would tie into the wires at the end of the harness (at the lights so if something shorts out it doesnt take out your entire light system of your bed)
Old 06-05-2009, 07:17 AM
EssentialJuice EssentialJuice is offline
thats a lot of wire will. tap in at the bed and fuse it. there will be an inch or so of potential wire shortage, but if you put the splice in the right spot, your chances of shorting out will be minut
Old 06-05-2009, 07:22 AM
storkerlovr storkerlovr is offline
you could look online for directions...good luck
