Advice: I want to learn to weld - Ford Powerstroke Diesel Forum
FABRICATION FORUM Let's see your ideas and work! :)
 1Likes
  • 1 Post By Kmay
post #1 of 10 Old 08-25-2014, 05:54 AM Thread Starter
ynpmoose's Avatar
Quoted: 7 Post(s)
I've seen plenty of welding done in person and on video, but never attempted it myself. Harbor Freight had a gas-less wire welder in their sale paper for $99 (similar to this Wire Welder - Save on this 90 Amp Flux Wire Welder). I was thinking this might be an inexpensive way to get started, but I'm not sure if this is the right type of welder for my purpose and if this thing might be total junk. I obviously need some gloves and a mask as well. I'm not looking to do any heavy-duty welding, just some light fabrication for my truck, RV, and around the house.
I looking for feedback from experienced welders.
Thanks,
Moose
SOLD - 2003 Excursion 6.0L 4x4
ynpmoose is offline
post #2 of 10 Old 08-25-2014, 07:02 AM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
It's a 90 Amp machine, you can find a coupon for $89 if you look, and for what they cost they actually are worth the money
But with a couple of of caveats;
Not much good over about 1/8" (with experience you can get 1/8 attached to 3/16)
Smoke, because it's flux-core you don't see the puddle well and not the best to learn on (a sm fan on Low, blowing that smoke away, helps)
And finally, MIG in General, can give you a sense of false confidence because if you don't know what you're doing you can make welds that look OK but really aren't $hit. They have not flowed into Both sides (TEST your practice welds, by breaking them, to know what you've got....)
So you need to learn what you can/can't weld, what it's supposed to look like as you do, and a whole bunch of little "details" about whichever process you're doing. It takes time & practice but EVERYBODY should weld!
There's a TON of YouTube on this, everybody likes "Jody" at WeldingTipsAndTricks (although I'm not sure he's got much on flux-core MIG), but I'm sure you won't have trouble finding others.
Get out there, give it a try, don't get discouraged, maybe join the WeldingWeb forum (they have a HF discussion there -> Harbor Freight) and learn to weld
NoRalPh is offline
post #3 of 10 Old 08-25-2014, 07:24 AM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
My buddy just bought one if them and it works ok for what he does. I was talking with him and he said if you by one don't use the wire supplied because it's junk. Step up to a good wire.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #4 of 10 Old 08-25-2014, 01:25 PM Thread Starter
ynpmoose's Avatar
Quoted: 7 Post(s)
Great info. Thanks!
ynpmoose is offline
post #5 of 10 Old 08-25-2014, 03:03 PM
Kmay's Avatar
Are you wanting to learn just for hobbies or to actually work as a welder?
Check out you local community college, some of them have programs and will teach you the proper way to weld, prep, and all the positions.
That's what I'm doing right now. 2500 a semester, they supply you with everything. They even have a good pipe welding program and when you are done you are ready to take your 6g pipe test. They are working on becoming an AWS accredited testing facility to actually certify.
Kyle
2005 F250 6.0l
ARP Studs - 6.4 Banjos - Blue Spring
EGR Delete - 4in Magnaflow Turbo Back
Sinister Coolant Filter - Fumotos - SG2
Zerex Cat EC1 ELC - High Idle - SCT w/SRL +
Atlas 40 - Isspro EV2's
Kmay is offline
post #6 of 10 Old 08-25-2014, 04:30 PM Thread Starter
ynpmoose's Avatar
Quoted: 7 Post(s)
Just for hobbies. The county vo-tech has adult night classes available. Level 1 is $400 for about 24 hours of training. I was considering that just to learn the basics.
ynpmoose is offline
post #7 of 10 Old 08-25-2014, 05:05 PM
Kmay's Avatar
That's a good deal for 400.
I would suggest getting a stick welder off of craigslist for a 100 to 200 and buy some1/8in 6011 or 6010 rods and just start burning them up. A lot of home hobby stuff can be achieved with a basic stick welder and some practice.
Once you get to where you can run a consistent bead start cutting them perpendicular and looking how much penetration your getting into both pieces.
Stick welder don't need any gas or or wire and you can weld with it anywhere.
A lot of people can run a decent looking bead with a mig gun but they don't have enough penetration. Once you get to where you can weld with a stick welder mig becomes easy and you can be a better judge of how much penetration you are getting.
sbluke55 likes this.
Kyle
2005 F250 6.0l
Kmay is offline
post #8 of 10 Old 03-24-2015, 05:09 PM
If you want to do body panels and sheet metal a cheapo MIG will get you through. If you want to do heavier angle iron fabrications at home you can't beat a stick welder for the $. A Lincoln tombstone off craigslist is a great place to start. Interview the instructor at the trade school before you sign up for a class and ask if you'll be using the Guided Bend Tester. Google it. Anybody can show you how to make pretty beads but you need to learn what a good weld IS. The Guided Bend Tester does that.
Walt the Welder is offline
post #9 of 10 Old 03-24-2015, 05:37 PM
'consent of the governed'
Patriot's Avatar
Quoted: 1138 Post(s)
Garage
Do some reading on arc flash, reflecting surfaces, and eyes feeling like you have sand in them. Then get a good hood.
Non Compos Mentis
My truck is too big for your screen.
Garysinisefoundation.org-----Independencefund.org-----Fisherhouse.org-----Shadowwarriorsproject.org
I invented a carbon sequestration device. I'm calling it 'tree'.
Originally Posted by Patriot View Post
There's a box?
Originally Posted by CrazyS0b View Post
Patriot... The box used to be a padded room for you before you managed to escape. Now they are too afraid to try and contain you again. Not to mention its way too much fun to just let you run wild.
What the heck is a Hy-Vee?
Patriot is offline
post #10 of 10 Old 03-24-2015, 07:04 PM
Red-Raider's Avatar
I have done a fair bit of welding, I would consider myself a "semiprofessional". My welding carrier was spent welding cattle pens, cattle barns, and the like. While I have no experience with the Harbor Freight welder, I personally would not touch it. When it comes to tools, don't skimp. Buy quality and it will last. I would also say start with a stick welder, get one that will go up to 200 amps and you can weld pretty much anything you will ever want to. Also, invest in a good welding helmet. Get a quality autodark, your welds will turn out a lot better.
2003 F-250 6.0 SD CCSB
Blue spring mod
CCV mod
Sinister EGR delete
Red Coolant
Rotella T6 5W-40 HD Oil
‎Scangauge II, Leveled, 20in rims with Michelin A/T's
Gooseneck fold down hitch.
Hollowed Cat
Chrome running boards
Ranch Hand up front, Custom in the back
Door dinger delete (my favorite mod)
Red-Raider is offline
