Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Off-Topic > FABRICATION FORUM
FABRICATION FORUM Let's see your ideas and work! :)
Old 01-03-2009, 04:11 PM
FX4STROKER FX4STROKER is offline
COTTONWOOD CREEK RANCH
Flux core aluminum wire
Hey everybody got a few questions. Ive got a miller bobcat arc welder and have some aluminum rods. has anyone tried these aluminum rods for a arc welder. I also have a little 120 flux core gasles wire welder. Does anyone have any sugestions about either. thanks
Old 01-03-2009, 04:51 PM
20stroker02 20stroker02 is offline
if you are able to put gas(100% argon) on your wire fed that would be the cleanest weld out of the both, also many suggest to run a new lead and trigger just for the aluminium
Old 01-03-2009, 06:29 PM
DAYTONA392005 DAYTONA392005 is offline
I have used the aluminum rods before......not a pretty weld but it will hold.
You need to practice on some scrap pieces first.....nothing like welding steel.
Good luck with this endevor...just make sure you practice first.
Old 01-15-2009, 07:42 PM
Rob454 Rob454 is offline
There is thiso other stuff out there its like brazing rods for alluminum. The nice thing is all you need is a propane torch. i used that stuff with good success. i welded up a case for my buddys dirt bike saving him 600$ 3 years ago and it still holds up fine.
There is a place by my house that sells it its 8 rods for 12$.
if youre gonna weld steel you should add gas to the welder you have. i have a cheapie welder also well it was 200$ so it wasnt cheap cheap but I added gas and its a WORLD of difference in welding as far as finish. Way cleaner welds
Rob
Old 01-15-2009, 07:49 PM
symbols symbols is offline
Nonsense specialist
Make sure they will even work on your welder. I bought some once and they were AC and I had a DC welder or vice versa...
Old 01-16-2009, 06:23 AM
icedevil icedevil is offline
the gun for aluminum on a mig welder is not cheap either, thats the only thing holding me back from aluminum...
Old 07-03-2009, 03:53 PM
rinnels69 rinnels69 is online now
If you are going to weld aluminum, ONLY use AC! It will work on DC (straight or reverse), but use AC unless it's an emergency. And make sure you brush the area down good with a stainless steel wire brush...make sure it's stainless steel, because a regular steel wire brush may contaminate the surface.
Old 07-03-2009, 04:16 PM
Big Daddy Sam Big Daddy Sam is offline
Yes, I'm Addicted
Not cheap at all. Miller is good machine though. Get Gas, (Argon preferably as previously stated) And practice, practice, practice on scrap. You have to "roll" a lot faster when welding aluminum as compared to steel.
