Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Off-Topic > FABRICATION FORUM
FABRICATION FORUM Let's see your ideas and work! :)
Old 12-11-2008, 11:28 AM
Goolsbymd Goolsbymd is offline
Project Abused
What to look for in a MIG welder?
So im getting ready to purchase my first mig welding machine and im looking for dos and don't on what to look for.
Old 12-11-2008, 11:32 AM
MrJohnWayne MrJohnWayne is offline
Thats Mr. Oil Leak.....
what are you going to be welding? thick stuff, thin stuff?
if you are welding thin any 120 welder will do, but IMO I would stick with linocn, hobart, or miller. You really do get what you par for. I also like machines that use gas over flux-core wire.
If you are going to be welding thicker metal 1/8 inch plus you really need a 220 volt welder.
as long as they have adjustable wire speend and voltage you should be good.
Old 12-11-2008, 11:34 AM
Project Abused
Thin stuff, never welded before than a few handfuls. Mostly want to get my skill up to par so one day when I open shop or work for a company im more skilled. Will be automotive
Old 12-11-2008, 11:46 AM
TANK'S 250 TANK'S 250 is offline
If you are only gonna do thin stuff,...I recommend buying a Tig machine,...
Old 12-11-2008, 11:50 AM
Project Abused
I see why your a coastie now, didn't score high on the asvab in reading?
Old 12-11-2008, 11:55 AM
Snap.... Tank does have a point though.... TIG is really good for thin stuff. A whole lot easier to control the heat.
if you are only going to be doing thin stuff then a 120volt welder will be great. You can get some cracker jack welders from northern tool and the like, but like I said you do get what you pay for. You can pick up a good 120 miller that will accept argon for about 1100. Alot of times you can find good used ones on ebay or craigslist.
Old 12-11-2008, 11:56 AM
Project Abused
Im just messin with Tank cause i know he can take it and not get hurt.
1100? They got em at Home Depot for less than 700
Old 12-11-2008, 12:00 PM
they could be cheaper, Been a while since I priced any...
Old 12-11-2008, 12:02 PM
Lincoln Electric Weld-Pak 175HD, 208/230-volt Wire Feeder Welder, Comes With Everything Needed To Weld Mild Steel - K2338-1 at The Home Depot
This one seems like a good deal. 600 bucks, it would be a good starter welder.
Project Abused
Well its for just the machine not bottles, I dunno if ill get bottles instead of just flux cored wire, don't wanna move bottles around and etc for just starting
