Would this be something you guys would buy?? - Ford Powerstroke Diesel Forum
FABRICATION FORUM Let's see your ideas and work! :)
post #1 of 12 Old 01-31-2014, 08:06 PM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
As a couple people may know from this thread What aftermarket accessory do you wish existed? im looking to eventually open my own machine shop in the next few years making those kinda niche truck accessories no one else makes and new takes on old ideas and im beginning to start designing up some things to have ready for when i finally open up. Just gonna post some things up as i draw them up and get some feedback from you guys.
Ill gladly take constructive criticism and possible ideas. I am by no means selling these products at this time or any time soon just seeing what you guys think. Thanks guys
First up is an in bed tank that goes around the bed so its takes up the part of the bed that isnt really used and will allow you to still use about 90% of your bed. The capacity is about 80 gallons and it would have a choice of manual valve(still toying with ideas) or electric solenoid valve.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 12 Old 01-31-2014, 08:11 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
I think the only way that would work would be if you went from the fender wells forward. Gonna be hard to get the fuel from behind the wells up to the front of the tank.
dhanna6powerstroke is offline
post #3 of 12 Old 01-31-2014, 08:15 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Ahh duh see this is why i need a second set of eyes. Simple enough fix having a line come from the 4 corners go into one then into the main tank. Good catch
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #4 of 12 Old 01-31-2014, 08:36 PM
usteffenhagen's Avatar
Neat idea.
I know you are still in baby steps here but what kind of protection would you use so a sliding load doesn't damage the tank?
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #5 of 12 Old 01-31-2014, 08:47 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Originally Posted by usteffenhagen View Post
Neat idea.
Well id probably have them powdercoated so that would protect the finish as for physical damage i suppose its just like any other in bed tank if you dont want damage to it secure the loads.
Another advantage to this is i would make sure to leave enough room to have a full sized toolbox as well for those who want it
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #6 of 12 Old 01-31-2014, 08:59 PM
Yeah, I guess if you aren't securing your loads then you shouldn't have a truck lol
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #7 of 12 Old 01-31-2014, 09:03 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
And maybe i could put some tie downs around it to ease in tying down loads since you would lose at least the back corner hooks for sure
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #8 of 12 Old 02-20-2014, 09:20 PM
rednex3's Avatar
Wow! I really like that idea. Here's an idea for you though. Might give you two different products from the original idea. For the newer trucks with one tank, just do the tanks in front of the wheel wells. For OBS trucks the tank section behind the wheel wells could feed the rear tank. All you have to develope or add is one more plumbing package to feed into the filler hose/neck assembly.
As a welder/fabricator and former fab shop owner who has built thousands of tanks, I love to see original ideas, however rare they are these days. This is one that has never even come into my mind and I have built tanks to go in some weird places. Sometimes the simplest ideas are the best ones. You have some thought as to cargo tie downs and how you are going to securely mount it to the truck. I don't see this being a cheap product, but with the right marketing it should sell.
From the stuff I read in your other thread, it looks to me like you are looking more at a fabrication business than a machine shop. Some really good ideas floating around though. You are going to have a significant investment in tools, time and sleepless nights. I wish you the best of luck buddy!!
Drew
95 Ext Cab F250
Dana 60 Swap
MBRP Turbo Back Exhaust
AFE Stage 2 Intake
Stock Injectors
1.0 Turbo Housing with Wicked Wheel 2
Bar None E-fuel kit
Bar None Bellowed Up Pipes
Isspro Guages
2 Rigid Industries 30 SRLs (worth every penny!)
All sittin on 35" Toyo Muds
So much more planned as $ allow!!
rednex3 is offline
post #9 of 12 Old 02-21-2014, 08:47 AM
johnnyroastbeef's Avatar
i'll just throw this out there...maybe you guys are already well aware of this technology...but I know they use it for automitve floor mats and also when they design some kinds of custom kitchen countertops. they use a laser on a tripod that digitally mesures the odd size and layout, (of either the floor on the truck or the counter top.) and the laser measures every little nook and cranny perfectly and creates a 3D image. that technology would work perfectly for making the tanks you guys are talking about and then have them made out of plastic. like injection molded. Again, I'm a dummy but seems like making aprototype that way would work really well. just throwing it out there. Plastic might be easier to just have them made and bolt them in the spaces? good luck!
NEW TRUCK!!: 2009 F350 Lariat CC Shortbed, 2.5" leveling kit, 35x12.5 R20 Toyo Mud Terrains,
-STOLEN 8/26/10!!!
2006 F350 CC shortbed, 2.5" leveling kit, 295/65/R20 Nitto Trail Grappler M/T's-STOLEN 8/26/10!!!
johnnyroastbeef is offline
post #10 of 12 Old 02-21-2014, 10:53 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Well pending i do end up buying my parents house my business may come to fruition soon than later so hopefully ill be able to start pumping more ideas/designs out here soon
Hmm i see, yea i was thinking about something like this to get the rear part to drain too. trying to balance ease of install with max capacity is the key here
Yea the new ideas are what i am going to try to pride my business on. Even with stuff that its already out there ill always try to through something into it that makes it better. As for holding it I was toying with using the tie down holes and then providing holes on the inside corner of the tank that your tie downs you took off will bolt to. I cant imagine its going to be cheap since its a lot more material than a normal tank would have but to those guys that cant afford a titan tank but need use of their bed and more fuel the need would be there i feel as long as my cost isnt more than a titan tank. Obviously it would have to be built to order.
Drew
Yea im thinking something along the lines of 50/50. Some of my ideas are machined parts and some are fabbed so if theres a need thats not being filled and its made of metal then i would make it.
Thanks for the support bud and any ideas ill take, i want to provide those things that people want but doesnt exist
Answers in red
Yes that is very viable, it would be nice then you could utilize every possible cubic inch. Unfortunately that wouldn't be until way later. That a bit of technology i dont think i could really spring for at first but if business takes off theres always room for improvement on designs as technology permits. Good suggestion bud
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
