just messin' around - Ford Powerstroke Diesel Forum
FABRICATION FORUM Let's see your ideas and work! :)
post #1 of 5 Old 07-22-2013, 02:02 PM Thread Starter
Underpowered's Avatar
just messin' around
where i work, side jobs are OK after hours so i was bored, and needed some shifter knobs any way so i whipped these up. both started as 2" 6061 aluminum round stock. all done on a manual LeBlonde Lathe and Bridgeport Mill.
first is my 4wd shifter knob on my 89 k5 blazer.
then i made this for the main shifter and had a buddy load up the dummy .357 rounds. i was going to make it to the exact dimensions of a .357 cylinder, but it was smaller than felt comfortable in my hand, so i upped the diameter some for a more comfortable fit.
'89 K5 Trail Rig--not at all stock
'98 Jeep ZJ DD-nearly stock
'00 F350 Tow Pig- bone stock.
Underpowered is offline
post #2 of 5 Old 07-22-2013, 04:48 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
Very sweet! Nice machine work. I need to get Woking on my 87 K5
Sent from AutoGuide.com App
2005 F350 CCLB FX4
juniorssrollin is offline
post #3 of 5 Old 07-22-2013, 04:49 PM
44magnum's Avatar
Quoted: 2 Post(s)
Those are very nice, I think you could sell those!
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #4 of 5 Old 07-23-2013, 02:34 PM Thread Starter
if i could set it up on a CNC, they could be profitable, but working on all manual equipment i would have to charge an arm and a leg to make it worth my while.
they are not hard to make at all, but i have a couple hours in each one by the time they are completely finished. one a decent multi axis CNC, you could whip one out in no time.
post #5 of 5 Old 07-23-2013, 02:38 PM
05f250harley's Avatar
Looks good man:thumbup:
05 Harley Davison Edition Arp head studs, SCT livewire TS, 03 turbo, PMM egr delete, PMM coolant filter, afe cai, blue spring, 6.4 banjo bolts, updated stc, standpipes and dummy plugs, 4" exhaust with no cat and no muffler
03 RCSB 205/100 warren injectors, BW s366, Lots of supporting mods to come
05f250harley is offline
