Anybody build a fan shroud without a metal brake? - Ford Powerstroke Diesel Forum
FABRICATION FORUM Let's see your ideas and work! :)
post #1 of 5 Old 05-08-2013, 05:24 PM Thread Starter
Lonesome7.3's Avatar
I need to build a simple square fan shroud out of aluminum. However, I do not have access to a metal brake. I have thought about clamping wood together and using a hammer. But the final product will not be the type of quality I would prefer. Any of you done this before or have any ideas?
Lonesome7.3 is offline
post #2 of 5 Old 05-08-2013, 07:51 PM
ZMANN's Avatar
Quoted: 1485 Post(s)
use aluminum angle for the bends
We Miss you Ronnie
ZMANN is online now
post #3 of 5 Old 05-08-2013, 08:46 PM
asian195's Avatar
Quoted: 2 Post(s)
I've seen people use 3 pieces of angle iron in a press. 2 pieces facing up, 1 down in the middle. ^v^ this is the best picture I can do to describe it. Obviously requires welding or similar. Hope this gives you an idea so you can make your own. Probably scratch it up really bad, so protecting it somehow is a good idea.
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
To Do/Wish list:
FICM tune
ARP Head Studs
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #4 of 5 Old 05-08-2013, 08:48 PM
asian195's Avatar
Quoted: 2 Post(s)
If you have a bench, you might be able to use a block of wood, clamp it to your bench, and bend it by hand. Won't give you a sharp bend, but might work out...
2003 F-350 6.0L.
Leveling kit
Airaid intake
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
To Do/Wish list:
FICM tune
ARP Head Studs
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #5 of 5 Old 05-09-2013, 04:40 AM Thread Starter
I like the press idea. I have access to one of them.
