aluminum roof rack - Ford Powerstroke Diesel Forum
FABRICATION FORUM Let's see your ideas and work! :)
post #1 of 4 Old 04-13-2013, 06:05 PM Thread Starter
1snakedoc's Avatar
aluminum roof rack
I'm looking to build an aluminum rack to go over my trucks camper shell "snug top". the bed is ~6.5' long i would like to make the rack 10' long, with it hanging over the cab. i really need to keep the shell to keep my tools dry but hate my ladders hanging out the back. the most that will be up there is 3 ladders and maybe some pvc and conduit. it dose not have to hold a ton of weight but would like to to be strong enough that in a pinch i could use it. will aluminum work what size tube pipe or angle would i need. i would like to mount my go-light and a ham antenna on the front, and some reverse light on the back. i was thinking of using 6061 t6 pipe or angle what size or what other aluminum would you think would work better and what filler wire? would mounting it to the top be good or do i need to run it down the sides to the bed rail.
i will post a pic of the truck when i can get one.
ford f-250 99 CC SWB
thanks matt
Matt PAA #117 99.5 F-250 XLT CC SWB 4x4 4R100 Warn M12000 GPR-LED. Foil Delete. 6637. 0.50. AC. Isspro Dual Pyrometer. AeroForce. FRx. HPx. DIY SS Fuel Lines. 03 HeadLights. 4" SS Exhaust. 6.0L Trans Cooler. BTS Tunes. Custom Lighted Tuner. IH Up Pipes. EPBV Delete. AIH delete. Isspro Boost Trans. Van Turbo WW2.
1snakedoc is offline
post #2 of 4 Old 04-13-2013, 11:32 PM
Quoted: 725 Post(s)
You could use 1" square tubing 1/8" wall.
Use the 6061 filler.
Corey@CNCFAB is offline
post #3 of 4 Old 04-14-2013, 11:14 AM Thread Starter
1snakedoc's Avatar
ok i did not know if 1" would be strong enough to work.
thanks
post #4 of 4 Old 04-14-2013, 12:30 PM
Quoted: 725 Post(s)
Going by what you said that you only plan on putting ladders and some PVC pipes 1" will be plenty strong enough as long as you use at least 1/8" wall thickness.
Square tubing is easier to work with too.
If you want it stronger you can fabricate a scissor truss style side rails and add more cross members to make it allot stronger.
https://www.google.com/search?q=alum...rp1JvDnkLyM%3A
