My Flatbed build - Ford Powerstroke Diesel Forum
FABRICATION FORUM Let's see your ideas and work! :)
post #1 of 13 Old 12-21-2011, 07:36 PM Thread Starter
jerg_064's Avatar
My Flatbed build
My future plans is to get my own cattle ranch in a few years so I'm prepping as much as I can now. Gonna be making my own flatbed on my truck. Didn't like the OTS bed's dimensions I've looked at and figured I could save some money doing it on my own as well...Not to mention all the learning I get from my first big welding project.
I'll be starting up on Friday I hope (weather permitting as I'm working on an outdoor concrete pad). So Far I got 1/8" tread plate, 4" channel, 3" Channel, 2"x3" angle, expanded metal, 3/4" square tubing and some jeep lights. Along with some random other stuff to help out. It's going to be 7'6" wide and 8'6" long and about 7" higher off the ground than the stock bed.
Two 4" channels will be the long sills or bed frame if you will. 3" channel will make up 6 cross members and most of the headache rack frame. I'll try to take as many pictures as possible and add each night as I progress.
James
2003 F350 Ext.C LB, 6.0L, 4x4 6spd SRW
DIY egr delete, DIY 4" straight pipe, DIY coolant filter, DIY CCV mod, PHP FICM/ECM Rollback, SCT LW, SGII, Skyjacker Steering Stab, Rotella Ultra ELC, blue spring, etc....
jerg_064 is offline
post #2 of 13 Old 12-24-2011, 08:12 AM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
Cant wait to see it come together.
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, TW tunes, 4" DP, Napa Intake, coolant filter, 140cc Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #3 of 13 Old 12-24-2011, 10:43 AM
Send a message via Skype™ to OnTheBio
Hey man I hope this goes easy for you. I'm a little less than 2 hours from you. I could probably come down on a day next week. Let me know which day you would need hands the most. I'm completely inexperienced in anything with welding but I can do what I'm told haha.
OnTheBio is offline
post #4 of 13 Old 12-24-2011, 04:33 PM Thread Starter
jerg_064's Avatar
Well as usual everything takes longer than you think it'll take. Haven't really gotten started on the bed yet, mostly all prep work. I have to work outside on some concrete pads that were covered in dirt and leaves and I needed some type of cover for when weather hits.
Also made some adjustable stands with some all-thread, sq tubing, 2x2 angle, some bolts and a lil bit of shimmying. Probably won't do squat tomorrow being x-mas n' all. Come Monday if it's dry enough I imagine I'll get the frame put together and ready for the diamond plate.
ID:	31898   Click image for larger version
ID:	31899   Click image for larger version
James
jerg_064 is offline
post #5 of 13 Old 12-24-2011, 05:02 PM
HaysKSFirefighter's Avatar
Cool project, can't wait to see the progress!
Tornado Alley PowerStrokers Director
2007 F-350 CCLB XLT FX4 ZF6 08 Mirrors, CTS, Gearhead, BD EGR Delete, Coolant filter, B&W, Custom rear springs, still rockin the stock head bolts and clutch!
HaysKSFirefighter is offline
post #6 of 13 Old 12-26-2011, 08:25 PM Thread Starter
jerg_064's Avatar
Frame
Got the bed frame pretty much put together today. Got the outside 'box' squared up and welded together. Then ran some string tight around it to help square up the 4 center cross members, and yea I took into account where the gooseneck hitch sits. Then placed and welded up those 4. Next came a LOT of sanding/grinding off the rust and residual whatever else was on all the surfaces to prepare for the primer. Used Valspar paint cans with their gun attachment and it really worked great.
Slightly modified the all-thread mounts. Drilled holes through the corner of the end cross members and put a nut about 1/2" down the rod so they work like dowl pins. Made it a bit more sturdy, was needed on account of a close call we had early on
I will still add in some extra support and braces here and there for things like the GN hitch door and stuff. That and welding on the diamond plate will require sanding some paint/primer back off in areas but since I'm working outside I needed to take some extra precautions against oxidation.
One note here. I tried grinding/sanding down the surfaces at first with a wire brush wheel at first and not only did it not work very well but the vibrations were insane so it wasn't really feasible (could've had something to do with the max RPM rating). Put a 120grit flap grinding wheel on the angle grinder and it worked great.
ID:	31927   Click image for larger version
ID:	31928   Click image for larger version
ID:	31929   Click image for larger version
James
jerg_064 is offline
post #7 of 13 Old 12-27-2011, 04:38 AM
Quoted: 6 Post(s)
Looking good so far
post #8 of 13 Old 12-30-2011, 07:33 PM Thread Starter
jerg_064's Avatar
Like I already said, everything takes longer than you think it's gonna, especially when your working alone. Figured I'd wait a couple days so it'd seem like I got a lil progress done, lol. And hope I don't mess up words too much, been drinkin a bit of wiskey (Pendleton, NW CONUS guys will know it, damn good )
Went ahead and painted the frame black. I didn't do this in perfect order, I know things could be handled better. But a 90"x48" piece of 1/8" tread plate ain't easy to move around by yourself. Then I laid the plate on top. Because I'm doing a funky arse length (8'6") bed I had the metal shop cut the sheets 6 inches short to lay side ways and then used the cutoff on the front. Was gonna use them on the back but my friend pointed out that the front should be a lower impact area and would be better for the extra seam.
Anyways, I messed up a little and the pass side front to rear length was a 1/4" longer than the driver side so I had to make some adjustments. Lined the front 6" plate pieces up with the front cross member and then lined the big sheets up with that. Luckily the sheets were actually 8'6.25" (which made the cutoffs 6.25") so then I just had to mark and cut a slither off the rear to line the tread plate up with the rear cross member. Then to re-enforce the front seam I added in some extra 3" channel, as you can see. Can't see that rear 1/4" cant with the naked eye
Then I measured the deepest lip of the tread plate overhang of the cross members; ended up being .07". So I cut all the rest to the same depth so as to let the tread plate sit on the scrap outer plate (4" flat, 3/16" thick) I had laying around. Cuts were all done with an angle grinder and cutting blade.
I fully welded the middle of the 2 big plates, stitch welded in order to keep down on warping. Probably did 20 different short welds spaced out alternating from pass to drvr side and I still got warping that you can see if you look closely.
ID:	32070   Click image for larger version
ID:	32071   Click image for larger version
James
jerg_064 is offline
post #9 of 13 Old 12-30-2011, 08:45 PM Thread Starter
jerg_064's Avatar
Next it's onto the sides. I had 2 pieces of the flat plate from a previous project. One a lil longer than needed, one a little shorter than needed.
With the warping on the tread plate and the fact that it's just plain hard to hold up a 102" plate on your own, I ended up using 4 cargo straps and 3 clamps to help me out here. Wrapped a couple straps around the first inner crossmembers on each end, then ran the plate through and tightened them up. Then added 2 more and the clamps. Tack welded the side up where it was flush and had to move both the straps and clamps around to flush different parts up. Oh yea, also a floor jack and piece of channel to help out pushing up that warped middle seems.
In the middle of all this, I measured and cutoff the longer plate. Took that cutoff, evened out that with the shorter flat plate and welded them together. Then ground down smooth one side that'll be on the outside of the pass side. Rinse & repeat same process above.
Next onto Fully welding up the side plates. Fully welded the top seams against the tread plate, will grind and smooth out tomorrow. Not really needed for structural reliability IMO, but for aesthetics. Welded up and ground smooth the front edges as far as I figure the bed will be sticking out so it'll look like one solid piece. I'll be cutting out long wedges on the bottom of the plates at the front of the bed so it's not as obvious that the plate is 1" longer that the crossmembers. The plate pretty much got rid of the warped diamond plate as I assumed it would.
Still have the gooseneck hatch, rear plate with door for storage and light holes covered with expanded metal. The sides and headache rack as well. Looks like I won't be able to finish the top window part of the rack yet due to needing some more 3" channel that my local shop ain't got in stock yet. Hopefully next weekend and it'll be about done. Will cut out & install stake pockets at a future date.
It's coming along.............slowly but surely.
ID:	32076   Click image for larger version
ID:	32077   Click image for larger version
ID:	32078   Click image for larger version
ID:	32079   Click image for larger version
James
jerg_064 is offline
post #10 of 13 Old 12-31-2011, 06:13 AM
Quoted: 6 Post(s)
Its coming along nice.
