Long bed tank in a short bed - Ford Powerstroke Diesel Forum
FABRICATION FORUM Let's see your ideas and work! :)
Old 10-04-2011, 06:04 PM
PMR = JUNK
How hard is it to put a long bed fuel tank in a short bed truck? What kind of crap needs done? I have the tank, pickup, sending unit, straps, everything except the filler neck.
Old 10-04-2011, 06:48 PM
Like the idea. Hope you get some good info.
Old 10-04-2011, 06:57 PM
Feedback Score: 9 reviews
Curious about this as well. My truck already tilts a bit with the full 25 gallon tank. So I can only imagine how bad it would be with a bigger tank.
Old 10-05-2011, 03:16 AM
PMR = JUNK
Probably not that much worse. Long beds don't seem to lean any more than a short bed. Every SD on the road has that lean though.
Old 10-07-2011, 10:04 PM
Send a message via AIM to Ewils35
messed up thing is i always thought it was just my truck that leans to the left.
Old 10-07-2011, 10:05 PM
messed up thing is i always thought just my truck leans(left rear tire leaks air)
Old 10-07-2011, 11:05 PM
BOSS LEVEL
How about just put the damn thing on and see what happens?
Old 10-08-2011, 09:48 AM
PMR = JUNK
Cause that would take time and energy and the possibility of it not working then having to put my regular tank back in. Thats why im askin about it first.
Old 10-08-2011, 09:52 AM
The Tamed Racing Driver
Measure it and see if its too long. I though they would run into the transfer case. Then measure to see if the straps are the same distance apart and the filler neck is in the same place in relation to the straps.
Old 10-08-2011, 10:59 AM
Feedback Score: 5 reviews
IIRC it was looked into, and the problem was the filler necks would not lign up correctly.
