Short to long bed conversion - Ford Powerstroke Diesel Forum
FABRICATION FORUM Let's see your ideas and work! :)
Old 10-04-2011, 05:59 PM
PMR = JUNK
As the title says, short bed to long bed conversion. Can it be done safely? Which would be the better option, getting a long bed rear frame and putting it on my truck, or just adding a section to my frame? I know some guys that could do this for me real easily, they are professional welders. I'm thinking make a "Z" type cut in the frame for more welding surface, then plate both sides of the frame around the weld, with a C channel that fits tight in the frame on all sides, then weld the plates and bolt them. Is that safe? Could i still tow heavy loads with the frame like that without it buckling or breaking?
Old 10-08-2011, 03:49 PM
Gotcha covered Jake read this, it goes from a question thread to a fab thread.
Frame lengthening - PowerStrokeNation
Old 10-08-2011, 04:04 PM
PMR = JUNK
Sweet, ill check that out.
Old 10-20-2011, 05:37 PM
It is safe. I have known a couple guys to do it with pickup trucks and a lot of guys that have done it with semis.
