Winch plate - Ford Powerstroke Diesel Forum
FABRICATION FORUM Let's see your ideas and work! :)
Old 05-12-2011, 12:00 PM
Send a message via AIM to 1tonpower
Winch plate
Its only in the first steps but it will be something when I'm done..
Muma wanted to help so I had he clean the slag off..
Old 05-17-2011, 08:06 AM
Old 05-18-2011, 08:04 AM
All the fab is done. I just need to finsh welding and paint it.
Old 05-20-2011, 04:13 PM
good bad or indifferent..im starting to think i suck at life..lol
Old 05-28-2011, 07:42 AM
All I have left to do is mount the solinoids.
Old 05-28-2011, 11:24 PM
That is pretty heavy duty.
Old 05-29-2011, 06:35 AM
It's over engineered... It's going to make a nice weight for winter traction
Old 05-29-2011, 06:40 AM
i think you should mount it directly to the frame put a bunch of cab lights on your truck... find a bridge and winch your truck into the air with merry christmas painted in your bed.... well it would make a great ford commercial lol jk man but really im in the army and tanks dont even have winches that big where did u get that thing
Old 05-29-2011, 09:42 AM
It's only a ramsey industrial series, 8k lb line pull..i made the mount so I can use it on the truck or on my goose neck dump trailer.
Old 05-29-2011, 04:53 PM
its overbuilt and underbuilt.
the 5/8 base plate really doesnt serve any purpose except for weight. The welds from the baseplate to uprights are pretty dinky for that size material and the way you have the winch setup, you should have at least 1 gusset, i not two per side, otherwise your just going to bend it, even bend the whole thing over. You could have built that whole thing out of 1/4" with proper gussets and stiffners, and save at least 30lbs.
using 1/4" angle(2x2?) will not hold up to the winches' full potential.
Probably a buzz kill, but IMO you should have posted before painted because there are some major strength issues you overlooked.
