Single stage vs. 2 stage compressor. - Ford Powerstroke Diesel Forum
FABRICATION FORUM Let's see your ideas and work! :)
Old 03-06-2011, 08:19 PM
Illiana Chapter Director
Not sure if this is the right place to post this but, here it goes. I'm looking at a new compressor. It is a Kobalt 60 gallon upright, twin cylinder, single stage for $479. I can step up to a 2 stage compressor but will cost a minimum of $800-$900 and I really don't have that extra money. My question is, will the single stage do what I'm wanting or do I need to step up to the 2 stage? I will mainly be using an impact gun and dye grinder, etc... No sanding o sand blasting. What do you guys think and post any pics. you have. Thanks. Shop Kobalt 60-Gallon Cast Iron Oil Lubricated Air Compressor with Heavy Duty Induction Motor at Lowes.com Anyone know or care to explain the nozzle fitting size? This one has a nozzle fitting size of 1/4" and I have found another on that is 3/4". I'm a and have no clue.
Old 03-07-2011, 05:26 PM
Well, I went ahead and bought the Kobalt compressor today. It should definately do what I'm wanting. My garage is a mess, so don't pay attention. Spring time job. Here it is.
Old 03-08-2011, 05:18 AM
Anyone know if this hour meter can be wired up so I can keep track of service intervals on the compressor? I know nothing about home electrical.
Redington Counters, Inc. - 722-0001 - Panel Meters - Automation & Control - Allied Electronics
Old 04-30-2011, 07:26 PM
Sorry so late, but yes it would work for your cause
Old 07-21-2011, 08:27 AM
Feedback Score: 5 reviews
Was curious how your compressor is working out? I'm looking at getting one for the garage and that looks like a good one.
Old 07-28-2011, 05:21 AM
Ya did it do what you needed.
Old 07-28-2011, 05:29 AM
Almostdunfukinwidit
Hey Doug your garage is messy.
That compressor should be more than enough to do what he wants.
I run a 1/2 inch impact pretty much non stop in the field with this thing
11 Gallon Powermate Direct Drive Oil Free Air Compressor with INVECTOR(R) Technology
Old 07-28-2011, 05:32 AM
My comp is pretty comparable to yours and I paint with it so you should do ok.
Old 09-22-2011, 06:53 PM
Always buy more compressor than you think you'll ever need. Saves having to upgrade later when you get things like a sandblasting rig.
