2 Post Lifts - Ford Powerstroke Diesel Forum
FABRICATION FORUM Let's see your ideas and work! :)
post #1 of 39 Old 02-08-2011, 11:56 AM Thread Starter
Powerstroke Techie
Clay Henry's Avatar
Quoted: 25 Post(s)
2 Post Lifts
I'm in the market for one of these. I have some repairs to do on the 6.0 and Ford wants 2800 bucks for the labor. So i figure I can buy a lift for that 2800 and do it myself (cab off) and then i have a lift as well as getting the repairs done on my truck for about the same money.
Anyone know much about these? The more I read, the more I find that there are several brands and price ranges.
I found this one and its one of the only ones I have seen that has 12' of clearance between the posts. I need that wide clearance because the lift is going to go where my camper is sitting in front of the north overhead door in my shop. Then on the rare occation i need to use the lift, i just have to movethe camper out. This way the lift isn't taking up spave persay. 12' clearance will make it easy to back my camer in between it. Alot of other lifts i was seeing only had 9-9.5 feet of clearance and my camper is 8' wide. thats a little tight.
This is about the max i want to spend on one.
http://www.bestbuyautoequipment.com/...al2-12k-fp.htm
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #2 of 39 Old 02-08-2011, 12:00 PM
Slacker
Evil Eye's Avatar
Quoted: 190 Post(s)
Feedback Score: 4 reviews
Looks like your link isn't working, Clay. MAN, I wish I had some space for one of these!!! I would love to be able to wrench on my truck by lifting the cab. It sure would make it easier than on my back! Keep us posted on what you end up getting and the install.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #3 of 39 Old 02-08-2011, 12:02 PM Thread Starter
Powerstroke Techie
Clay Henry's Avatar
Quoted: 25 Post(s)
Will do Shawn.
Linky fixed.
post #4 of 39 Old 02-14-2011, 02:10 PM
countryraised's Avatar
You will need to have thick enough concrete under them, usually 6"+, or else some very large foot plates added to spread out the weight.
Vince
John Deere product developement
FOR SALE '99F350 2008 F350 mini maxx'd
countryraised is offline
post #5 of 39 Old 02-15-2011, 08:02 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
More $$ but get a Bend Pack 12k...you will be much safer..Ive got both a 10k and a 12k and won't use the 10k with a PS unless the other lift is tied up.
CT Performance, Inc. is offline
post #6 of 39 Old 02-15-2011, 09:06 AM Thread Starter
Powerstroke Techie
Clay Henry's Avatar
Quoted: 25 Post(s)
I actually was looking at a Bend Pak last week after someone pointed me to it. 2600 bucks delivered from Garage Equipment Supply | Garage Tools and Automotive Equipment. I was looking at the 10k lift and I think it will be fine. The majority of what I'll be doing with this is lifting the cab only. I may use it to do brake jobs also but i won't be under it for that. Their specs say 4" min concrete thickness and 2600 psi strength. I have 4"-4 1/2" and 3000 psi.
post #7 of 39 Old 02-15-2011, 09:12 AM
Adam-Arc's Avatar
Some lifts have a bar across the top with a safety bump stop. Make sure the camper fits.
By the way, once you have a lift you'll use it more than you think. And it can be a source
free beer. 6 pack per hour, case for 5 hours and 1/4 keg per week end.
97 F350 CC 4x4 Auto Welding Rig
Steamfitters Local 475, Newark, NJ
IDM mod/Homemade CCV/10k/6637/3"dp/4" exhaust/no cat/muffler
Adam-Arc is offline
post #8 of 39 Old 02-15-2011, 09:17 AM Thread Starter
Powerstroke Techie
Clay Henry's Avatar
Quoted: 25 Post(s)
Yeah the cross bar is almost 12' up and the camper will fit under that.
I can imagine using it for all my buddies projects...
post #9 of 39 Old 02-15-2011, 09:53 AM
Let's Run'em
TwinTurboStroker's Avatar
Quoted: 5 Post(s)
I want to be like Clay when I grow up..........
-Julian
4th 6.fo
TwinTurboStroker is offline
post #10 of 39 Old 02-15-2011, 10:03 AM
Adam-Arc's Avatar
What's yer address?
Clay's shop post post-lift-
Adam-Arc is offline
