| FABRICATION FORUM Let's see your ideas and work! :) |
DIY Traction Bars 99-03 PSD
I did this over at the Nation and I have noticed there isn't a lot of build threads here so hopefully someone can use this thread for guidance on their own build.
The bars work flawlessly and I have not noticed any difference in ride quality. On Edit: Could this possibly be a sticky in the Fab Forum for others wanting to build their own????? Last edited by dirtboy25; 09-03-2010 at 06:40 AM. |
1/4" strap 3"x6"
![]() I made this pattern at work. 1/4" plate. The bolt hole is 9/16" - 4 1/8" from the bottom of axle tube. I made sure to leave a +5/8" space in front and behind the axle tube in case i had to mount them over the u-bolts. ![]() I cut a 3" spacer and placed it in the bolt holes. Mocked it up and welded it. And make sure to check, double check, and triple check for squareness. ![]() ![]() ![]()
All of the parts except for the axle mounts and tubing were purchased at Ballistic Fabrication
This is the bushing I used in the rear to go between the axle mounts I built. It is made form 2" DOM and overall width is 3" ![]() This will be in the front. It is a forged chromoly 2.63" Ballistic Joint 3/4"-16tpi ![]() Tube adapter. 3/4" 16-tpi for the Ballistic Joint ![]() Frame mount... Again, for the Ballistic Joint
The center of the hole is 1 1/8" from the back plate, and the bushing is 2" OD. So,.... i should have an 1/8" gap when it's in there. If i do put the brackets on the bottom of the frame i wont have to straddle the u-bolts. But i would have to remove my sway bar because it is in the way. I don't really want to remove it though. I can add on to the frame mounts to allow them to bolt up to the outside of the frame if i need to. I cant decide if i want to remove the sway bar or not. Im still looking around and trying to find some helpful info on others that have removed it. And I was also wondering if i could build my own and make it narrower.
For the 2" DOM it will cost me. I don't know the price for it but im getting 12ft and im guessing it's not going to be cheap either. The bushings, heims, frame mount, and tube adapters were purchased from Ballistic Fabrication.Ballistic Fabrication - Manufacturers of Precision Offroad Fabrication Supplies hopefully they arrive in the mail today so i can work on finishing them up this weekend. As far as height. I have removed the blocks from the rear which dropped it quite a bit, and i plan on dropping the front an inch. Im trying to figure out how. Some have said to use excursion leaf springs, but im wondering if i could build a set of drop shackles. |
I had to remove the shock mounts on both sides to get a good weld all the way around. These are the mounts i made. It rained the night before i got to paint them so they got a little rust on them. No biggy though. And yes, i did go the great lengths to make sure they were as straight as could possibly be to ensure there would be minimal binding.
I mocked up the bars, mounted them to the axle mount and cut them to length so that the front heim joint would be even with the carrier bearing. After that i attached the frame mount to the bars, positioned the mount and tacked it in place. Removed the bars and welded it.
This should give you an idea on how long they are. The final length cam to 61-1/4" |
Now that the mounts were in place it was time to paint the bars. I lightly sanded them by hand, cleaned them with carb cleaner, and rubbed them down with mineral spirits.
I chose to go with a textured paint, I thought it would look nice on the bars and i am satisfied with the outcome. |
After i let dry for 24+ hours i put the bars back together, set them at 61-1/4" and mounted them up.
I used full synthetic grease, don't know why, it's just what i had layin around. I pre greased everything and mad sure the bushings and joints were well lubricated before mounting. They didn't send jam nuts with the heims so i just used regular nuts. |
This is the only picture I have of them at a distance. |
