| FABRICATION FORUM Let's see your ideas and work! :) |
horse trailer restoration.
Just got given a 1977 circle j 2 horse trailer. Needs alot of restoration work but considering the age its not in bad shape at all. floor is pretty solid and it was taken care of most of its life.
I just wanted to see if I can get any tips from anyone who has done such a project. I need to get this thing sanded down all around(axles and frame too) and painted. Theres a few spots where itll need bondo on the body, some sheet metal can be replaced. but its pretty solid over all. Got a fiberglass topper(best part about it!) so any tips? my friend suggested wet sanding with 200 grit paper. its probably alot for me to take on but I know i'll have help. The brake on the left is also sticking, and the lights dont work, im assuming the brake is probably rusted and stuck and the lights probably been chewed up by something, gotta find the wires and see how they look all around.. it has tires but they need replacing, dry rotted but they got home ok.... alriighttt throw tips my way! This is going to be my rig and i want to get it road worthy by late september latest!! |
btw i have just about access to any tool possible.. ha! and the wheel bearings didnt make a single noise at all when we were drivin it.. they have rubber caps on them, im guessing they're serviceable and need it.
your best bet imo would be to have a reputable place do it for you. simply because you could have them strip it down, blast the entire thing and repaint it and re-wire it all and basically have a brand new trailer
ha ha if i had money i wouldnt bother todo it myself.. the fact is i dont.
How did this end up going for you? I actually just spent about 2 months completely restoring a 16ft gooseneck stock trailer and could definitely help if you still need it.
