| FABRICATION FORUM Let's see your ideas and work! :) |
got any updated pics?
I bet the white car looked real good with the chian marks across the body. LOL
Redneck style.... Doug |
"I bet the white car looked real good with the chian marks across the body. LOL
Redneck style.... Doug " I'm not sure what this means ....... Am I missing something ? |
You will have to look at his pictures to see that one.
Doug |
no up dates =\ i have a lot on my plate right now...but i do have the angle i need to make a cradle?? if that makes sense for you. on the bottom of the can youll see some rails that keep it on the roll off frame. im going make the frame of the trailer cradle that part. im still up in the air about making it a tri-axle or tandems. if i go with the tri set up im thinking about making one lift able. its a 15yrd can and if i handle the weight loaded then whats the point of having the space.
the thought of cutting two feet off the top and putting stake holes in it but i think thats a lot of work to do in my back yard with only a torch. i need the chale for the goose neck frame and the pistons, id like to use two 2 stage lift pistons. i know that the CAM-LINE dump trailers use them but i cant find them anywhere online. the axles will come last if i like the way it turns out. goal for before winter if to just mount the can on the frame so i can move the damn thing around |
