new winch set up - Ford Powerstroke Diesel Forum
FABRICATION FORUM Let's see your ideas and work! :)
Old 07-21-2010, 10:53 AM
Send a message via AIM to 1tonpower
new winch set up
Uploaded with ImageShack.us
i built that tank last year and had the pump laying around for about the same amount of time. and my jeep is off the road for a while so i figured id put the winch to good use....i started yesterday mounting the tank, pump and valve. and today i went down to a local hydro shop to have my hoses made. all but one hose is in place but not tight yet. i have one more fitting to pick up and ill be done for now...right now the winch is permanent...quick connects are on order. i should be up and running tomorrow. the winch is 10,500 mile marker hydro unit...oh yea and the bed will be power tilt as well ;]
Old 07-21-2010, 11:18 AM
riddin' high
Send a message via AIM to Dasaliac03 Send a message via Skype™ to Dasaliac03
pics didnt work
Old 07-21-2010, 11:19 AM
riddin' high
power tilt? i wanna see it!
Old 07-21-2010, 12:47 PM
i dont know how to use image shack...anyone other good hoisting sights besides photo bucket
Old 07-23-2010, 04:42 PM
its up and running. all i have to do is mount the rollers and wire the power leads. and make a handle for the tilt valve. i ran into a snag with my plumbing but i got it all worked out. power tilt up and down works mint..when the tail hits the ground it will lift all four wheels of the ground.
the two switches you see on the winch control box are for the in and out of the winch. the remote still works too.
