Auxillary fuel tank??? - Ford Powerstroke Diesel Forum
FABRICATION FORUM Let's see your ideas and work! :)
Old 03-23-2010, 05:25 PM
I need an auxillary fuel tank under my current tool box, what's the best material to build it out of (steel or aluminum)? It will only be used for long trips.
Old 03-25-2010, 08:55 AM
Aluminum would be my chioce if you have the abilities to make it.
Old 03-25-2010, 09:04 AM
Runnin'wita2cylhandycap
Make sure you put enough baffles in it to help stop side wall flex.
The "pop" that you hear when filling with fuel is material flexing and sooner or later it can cause trouble.
Old 03-25-2010, 09:22 AM
Send a message via AIM to 1tonpower
im not sure but if you get stopped by the man he might look for a DOT plate.
Old 03-25-2010, 02:20 PM
That is a good point. You may want to get it inspected.
Old 03-25-2010, 08:39 PM
i no alot of ppl in text that have made there own and dont have dot on them what r u usein it for to fill up equipment or for ur truck
Old 03-25-2010, 08:51 PM
I vote for aluminum. Just be sure you add baffles in it.
Old 03-25-2010, 10:28 PM
It will be used for the truck, gravity feed into factory tank. It will be baffled. And I am "the man" u speak of, so no worries there
Old 03-25-2010, 11:40 PM
aluminium man no worries...half inch feed like with an electric vale and youll be good to go. just dont over fill the stocker it tends to make a mess
Old 03-26-2010, 06:03 PM
I acendently over filled my stocker at the truck stop the other day. There was a good gallon on the ground before I got the punch shut down
