Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Off-Topic > FABRICATION FORUM
FABRICATION FORUM Let's see your ideas and work! :)
Old 10-28-2009, 10:23 PM
builtnotbought builtnotbought is online now
Air comrpessor.
Lets see what y'all have for air system, i want something to run my air horn but at the same time being able to pump a 35'' in less then half an hour.
Old 10-28-2009, 11:15 PM
AgentAustin AgentAustin is offline
Send a message via AIM to AgentAustin Send a message via MSN to AgentAustin Send a message via Yahoo to AgentAustin
For your truck? Or for your shop?
I'm guessing truck since you said air horns.
Old 10-28-2009, 11:53 PM
choupique108 choupique108 is offline
In search of 20s
Location: Lake Charles, Louisiana (currently Shawano, WI)
i have the viair 450C and i love it. Its a 100 percent duty cycle compressor so it can run a really long time without needing a break. I have it and a 5 gallon tank and if i had to do it again, id get a larger tank for sure.
Old 10-29-2009, 08:58 AM
edosher edosher is offline
I'm working on a 4.5hp 12dc Warn winch motor coupled to a York 210 compressor. 12.8CFM @120psi, more than enough for my horns and air demands!! I had the York engine mounted in my old Dodge, but there is no clearance under the hood on the 7.3's. I'll post picks when I get it done.
Old 10-29-2009, 09:01 AM
Snake Snake is offline
You can get by with a crappy compressor if you have a big holding tank for air. Or one that can withstand high psi (most are rated for 200 psi). That being said, make sure you get a 100% duty cycle compressor. Otherwise, the compressor will shut itself off in the middle of a job when it gets too hot. I'm running a ViAir 480C with a 5 gallon tank and am very happy with it.
--Snake
Old 10-29-2009, 09:32 AM
bens99f350 bens99f350 is offline
ViAir 480C here, works great!
Old 10-29-2009, 09:34 AM
NotStock NotStock is offline
Im running twin ExtremeAires and a 10 gallon air tank. 8 cfm and 150 psi max pressure get the job done for sure!
Old 10-29-2009, 09:48 AM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
nice... got a link to them? i was just going to run dual 450C's and 2 5gal tanks
Old 10-29-2009, 09:56 AM
Here ya go brotha! ExtremeOutback.com . If anyone wants one, I have 2 extras that I would sell for $375 each plus shipping.
Old 10-29-2009, 10:19 AM
do you still have yours mounted in that ammo can or took them out?
