Pole Barn - Ford Powerstroke Diesel Forum
FABRICATION FORUM Let's see your ideas and work! :)
Old 09-04-2009, 06:36 PM
Exclamation Pole Barn
Im building a 24x36 pole barn here at the house and I will be setting posts tomorrow and I cant remember or find the formula to use to measure to make sure that everything stay square. Also if anyone near me here in ohio there will be food and beer to all helping hands Hope you guys can help me figure this out. Thanks!!
Old 09-04-2009, 06:52 PM
Measure the length of the opposite corners across the floor area.
Old 09-04-2009, 06:56 PM
Shade tree mechanic
6-8-10 is the one I use. works every time. What foundation is it going to be on.
Old 09-04-2009, 07:11 PM
Its on 6x6 posts that are 3 2x6's lamintated together. The holes are 48 inches deep, then 8 inches of concrete that the posts will set on. I will then tamp chips and dust are the posts. The floor will be compacted chips and dust. There are 5 posts a side with 2 at each gable end. One 16 foot wide door on a gable end. Trusses will be set 48 oc
Old 09-04-2009, 07:13 PM
Shade tree mechanic
Excellent. sounds like a pretty stout building. Do you understand the squareness measurement of the 6-8-10 formula?
Old 09-04-2009, 07:25 PM
If I didn't have to work, I would come out. Your closer than I thought you were. Mapquest said an hour and 14 inches so I could do it in about 45 minutes.
Old 09-04-2009, 07:45 PM
Chug-a-lug!!!
The diagonal of your 24X36 building will be 43' 3 1/8". It' called the pythagorean theorem. "A" squared + "B" squared = "C" squared.
24X24= 576
36X36= 1296
576+1296= 1872
Square Root of 1872= 43.26ft= 43' 3 1/8"
Hope this helps.
Old 09-04-2009, 07:47 PM
Shade tree mechanic
24X24= 576
36X36= 1296
576+1296= 1872
Hope this helps.
This guys all over it. Framing experience I take it.
Old 09-04-2009, 07:48 PM
Shade tree mechanic
Or just a genius at math...
Old 09-04-2009, 07:49 PM
Shade tree mechanic
or both on a daily basis
