- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| FABRICATION FORUM Let's see your ideas and work! :) |
Brazing Cast Iron?
I have an old corn planter that Im restoring and I just noticed that on the frame it has a big crack. What is the best way to repair it? I was thinking about brazing it because I was told it can't be welded. My main concern is that its 100 years old and I don't want to screw it up any worse. What should I do? Thanks and heres a picture of part of it when I was priming it today...
| Sponsored Links |
Thats the problem though if I break it im hosed because that piece is nearly impossible to find and its 100 years old. I was told about heating it slowly too. I think the reason it cracked is because it was repaired before. I think some idiot just heated it up too quick and made it brittle . I guess Ill try the oxy acetyline brazing.
The key is to pre-heat AND post-heat the cast iron. Get your pieces prepped by grinding a slight bevel all the way around both pieces to be brazed or welded. Welding cast iron requires the use of nickel welding rods. They work great, but they are pricey! When you are brazing, keep the pieces tight together...an extra set of trusting hands with heavy gloves works good if you can find them. Pre-heat the parts with a torch to a point just before it starts turning orange...basically as hot as you can get it without changing color. Lay down a bead about 1/4 - 3/8" wide...the brazing acts like a glue, so more is better, to a point. After you are satisfied with the finished product, keep the torch going and keep the flame on it, backing it away an inch or 2 every couple of minutes. You can even place it in an oven set at 450 and turn it down 50 degrees every 15-20 minutes until you turn it off, then leave it in the oven until it is cool to the touch. If you choose to arc weld it with the nickle rod, follow the same pre/post heating instructions. I went to a vo-tech school (graduated as a certified weldor--Vert up and overhead, stick and MIG) before I joined the USAF, and did some fixes just like this as well as an engine block with a crack...just drilled a hole at each end of the crack, grooved it out about 1/8", preheated the area, welded about an inch, re-heated, weld another inch, repeat until done. Worked like a charm. |
Dude, the Henrob 2000 can do that No Prob!!!!!
look it up on youtube. I saw it! |
| Sponsored Links |
