Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 06-22-2009, 02:26 PM
Tree Killer Tree Killer is offline
05' 6.0 won't run
Its a 05 6.0 it will crank, run rough, drive a short distance and die. and repeat. filters were replaced and it didi not solve it . Are fuel pumps covered under factory warranty? Any one got any ideas?
Old 06-22-2009, 02:40 PM
BUMP BUMP>>>>> BRB I gotta go tow it to somewhere;( The service man. @ dealer said he didi'nt think the fuel pump would be covered. Its only got 40,000 mi. on it
Old 06-22-2009, 03:28 PM
Would the HPOP cause this ? BUMP BUMP I don't think the fuel punp would be covered I was confused with the HPOP. Its to HOT for this $H1t. We just bought this truck on friday, drove it home(700 miles) and now today it takes a dump. Its going to the dealer, There is no SES on,
Old 06-25-2009, 09:13 AM
Slartibartfast Slartibartfast is offline
sounds like HP oil problem. IPR, STC fitting, branch tubes??
Old 07-01-2009, 01:42 PM
It was 7&8 injectors bad and the fuel pump w/ 30lbs. The pump was covered.
