OIL LEAKING BAD - Ford Powerstroke Diesel Forum
Old 06-22-2009, 12:57 PM
OIL LEAKING BAD
hey guys kind of a newbie here.....i have a pretty good knowledge of gasoline engines and i am just getting my feet wet with diesels here. So this leads to my major dilema. I have a 2000 F-250 with a 7.3 and i pulled up to my house last nite and did a little look over my truck and seen it was literally pissing oil. I was reading through the forum and saw what seems to be a common problem as far as a HPOP leaking? Now i have no idea what this is or where it is. There is a lot of oil in the valley and it is all over the bottom of the motor...i was lookin around today after work and rite behind the fuel filter (the one on top of the motor) and kind of underneath it there is a bolt with a o-ring that looks like it is tore and popped out and that seems to be where it is leaking from......so any help would be greatly appreciated and as soon as possible to for this is my only vechicle
Old 06-22-2009, 08:00 PM
well i pulled that bolt out and replaced the o-ring and it seems to have fixed the problem.....but the hpop? is that your high pressure oil pressure regulator?
Old 06-22-2009, 08:06 PM
hpop is your high pressure oil pump that feeds your injectors
Old 06-23-2009, 02:39 PM
yea i have found that out....but thank you.....well i though i fixed it with that o-ring but i guess not i drove it to work today and stopped a cpl times to check the oil and it seemed fine.....then i drove it home and checked the oil and looked under it and it was pissin again! dam it man! so i took it to a friends shop and hes gonnna check it out cuz im still not to confident on my diesel mechanical skills
