sputtered and died need help!!!! - Ford Powerstroke Diesel Forum
Old 06-17-2009, 06:55 PM
I just installed:
stage 1's
ats intercoller
203 thermostat
diesel site boost fooler
tymar intake and DP
already had:
tw chip
Problem after getting the truck back together I drove it for 100 mile and it started acting up. It started making a popping noise through the exhuast, CE light came on and ofcourse lost power. it started twice after the first time I heard it the on the last time it did it died and wont even try to fire. Idk know what is wrong and would love to hear any ideas u might have.
Thank you for looking.
Old 06-17-2009, 07:15 PM
by the way it is a 96 F250 7.3 with 5 speed
Old 06-17-2009, 07:20 PM
<<---"Shadow"---
Do you have a way to read codes? That would be a HUGE help.
Old 06-17-2009, 07:40 PM
does a regular OBD II diagnostic tool work or do I have to have something special? I talked to my local Ford dealer and they couldn't do anything unless I had the truck there
Old 06-22-2009, 03:05 PM
Obd scan tool shows no codes and I replaced the CPS and still won't start.
When I crank the motor over the fuel pressure only gets to 55 psi and if I remember correctly it use to not start untill it hit 60 psi. would that have anything to do with it?
Old 06-23-2009, 05:06 PM
any ideas?
Old 06-24-2009, 04:57 AM
Have you tried swapping the relays around? Mine recently had problems and I could have saved a tow bill if I would have done that first.
HPOP oil level?
IPR sticking?
IDM harness?
Try laying a gas soaked rag over the intake and spin it over to see if it will fire. If it does you know it is a fuel issue.
I'm sure a tech will be along with more. Put up your location as someone may be close to you and able to help out.
Old 06-24-2009, 03:40 PM
HPOP oil level?
IPR sticking?
IDM harness?
My truck is in rolla, mo. Did u mean diesel fuel or do u acctualy use gas in the rag
Old 06-24-2009, 03:53 PM
did you check your fuses??
Old 07-17-2009, 03:28 PM
I haven't been able to work on it untill today. I rechecked the fuses and they r all good and I also pulled my idm apart and it's ok to.
What should I check next?
