She Died on me at 75mph now won't start
Hello all this is my first post looks like a great source of info. Hopefully someone can help me out with my problem.
I was coming home from northern WI. Temp was -13F when starting truck. She started up fine, I let it warm up for about 20 minutes. I then proceeded home at highway speeds. I was driving along for over an hour at 75 and everything seemed fine then I noticed some missing and I was loosing speed. I pulled to the side of the freeway and my truck was still idling but it sounded like there was air in the fuel system. Truck was rattling bad. I then shut the truck off and drained off the filter. I went back in and tried starting the truck, it started but sounded aweful with no power. It just kept getting worse and worse till it wouldn't even start anymore. The temp was -8F at this point. I was close enough to a truck stop to run there. I went and they sold me 2 bottles of Isoprople so I added them to my tank of striaght #2 Diesel. Before the trip I filled my tank and added a whole bottle of Power service. I thought the entire bottle would be more then enough to keep my fuel from gelling. Well my truck still didnt start after the alcohol and a hour of waiting and about 10 drainings of the filter housing. Someone towed me up to the truck stop where I topped off my tank with thier winter blend and tried to start her again. All I get is a knock knock knock when its turning over. But it does not want to go. My truck is now sitting at the truck stop a hour from my home. I am going to go up there as soon as it warms up a bit to try to get her running. I have a spare CPS (replaced it about 3000 miles ago) I am going to bring it along but I don't know what else to try. Anyone have any ideas of what I can try? She is out in the middle of nowhere so if I can't get her going its the hook Thanks in advance, Chris Oh yea shes a 2002 excursion 7.3 powerstroke |
First off let me say welcome to the site alot of good people here and alot of good info. Down below I list what I believe is your problem.
Cam Positioning Sensor, it is located on the front engine cover above the crank pulley, at 1 o'clock. It has a metal tab sticking out of it and a wiring harness going to it. I suggest replacing that. It costs any where from 110 dollars to 150 dollars depending on where you go. I am willing to bet that is your problem. The 7.3L is notorious for having these sensors fail. |
I replaced it about 3000 miles ago. I was planning on bringing the old one along to try since there was nothing wrong with it. I was also looking for other items that I could check/change out to find my problem since its an hour away from home.
Thanks, Chris |
Sounds to me like your fuel is gelling. Tow it to a place where your can get it warmed up like a garage and give it another shot. Make sure your batteries are charged up also.
if your fuel is gelling put in a new fuel filter.
Also did you run it to low the fuel that is. Maybe your guage is off a bit just a thought.
i had similar symptoms a couple years ago, ended being that my fuel pump was bad.
I left my house with a full tank of #2 and a quart of Power service. Drove all the way up 145 miles without a problem. Truck sat till this morning -13 and started right up drove about halfway home about 70 miles and thats when she died. Tank was at about 2/3rds full when the problem started. Since the problem I have added 2 pints of Iso heet (I don't like adding alcohol to my fuel) with no change. I then was towed to the truckstop and topped off the tank (about 15 gallons) Still nothing.
The whole time the fuel flows nicely out of my drain on my filter housing if I open the valve. If it was gelled up wouldn't the fuel not come out of the drain? |
Hmmm makes sense to me if you have fuel flowing at the drain your not gelled up. Maybe it is the fuel pump. I don't know what the easiest way to check that would be other then to listen to see if it cycles or maybe see if it will fill your fuel filter bowl. Hopefully somone with more knowledge will chime in
I am really hoping its the CPS but with only 3000 miles on it?????? I just don't want to drive an hour just to let the old girl sit in a parking lot again.
Thanks |
