- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
My wife was talking bad about the old girl Saturday before we went to Sam's and I guess she must have ticked her off. I was sitting in the lot idling with the AC blowing and got tired of waiting (15min) so I shut the truck off.
No Start after that. I ran the batteries down trying and bought a new battery and tried some more. I had it towed home and she hasn't started since. History - some problems with hard starting when hot - never a no start. I was planning to change IPR o-rings and see if that helped the problem before this happened. 1994.5 5-speed 175,000 miles, moderate blowby (even no chugging) never ran hot always runs a little cool on the gauge but cycles the thermostat (205 degree) replaced fuel filter afterwards still no start. I tried to remove plug from top of HPOP to check oil and plug is stuck. No codes other than lower than expected PCM voltage from (I assume) changing the battery. Tach moves when cranking. I don't notice any oil pressure buildup on the gauge when cranking. (and I wound on it for awhile) I need a troubleshooting plan of attack and test sequences. I have some test equipment and can get what I need. Someone give me a path to follow. |
| Sponsored Links |
How do I determine that? I was going to get a gauge to hook on at the filter. Even if that indicates presssure, that is no guarantee the fuel is getting to the cylinders. I shot it one time with a little ether and it bucked and carried on but wouldn't keep running. My gut feeling is that it is a fuel problem. I just don't know the testing processes for the different fuel components and don't want to start parts swapping until I run out of money. Water and lift pumps were replaced last year and the truck hasn't run many miles (10k) since then. |
I have fuel pressure. Checked it (informally) and it spurted all the way to the fender. I was looking at the IPR and the black plastic part that the harness plugs into is loose. It freely moves sided to side about a quarter inch. If you guys have links to procedures for changing the IPR and HPOP, post them up for me as I think that is where I will ultimately be headed. |
Finally got the plug out of the HPOP and the oil level was waaaay low. I filled it back up and still no start. Unplugged the ICP and threw a code. Plugged it back up. I'm getting P1661 and P1668 codes. I also talked to Bob at Diesel Site about their pumps and he suggested a Auto Enginuity diagnostic scanner. I was just about to pull the trigger on that one when he said it hooked up to a laptop. Well, I don't have one of those. I guess I could put my desk top on a cart or something. He also suggested a gauge called an Interceptor that can capture the data and codes although you can only see two at a time. I tried to call them to find out just how much info it could pull from my 94.5 and they don't have a phone # on their site. Just a forum to contact through. I'm still leaning towards the IPR/HPOP problem and likely should replace the low pressure oil pump while I'm in there. I really hate to just throw parts at something. |
Are there other scanner options I don't know about? I would really like to be able to run a buzz test and other diagnostics that I can't do with just a gauge.
| Sponsored Links |
