Thermostat Replacement - Ford Powerstroke Diesel Forum
Old 06-13-2009, 08:07 AM
Doing flush and fill on coolant. The new thermostat has a gasket built in to the thermostat (pics on left). The old thermostat I took out did not have the gasket built into the thermostat. Does the separate gasket (pictured at the bottom of the photo) go above or below the new thermostat, or do I even need it at all?
New thermostat is on left.
[IMG][/IMG]
Old 06-14-2009, 10:09 AM
The gasket on the new one should be the only one you need. Set the tstat in place and see if the gasket sits above the register enough to seal.
Old 06-14-2009, 10:34 AM
wriott
Guest
Posts: n/a
it also wouldnt hurt to put some RTV sealent to help out. i have never had good luck getting them not to leak on the first try
