7.3 trouble please help - Ford Powerstroke Diesel Forum
Old 06-10-2009, 04:46 PM
I have a Snap-on Solus scanner hooked up. It showed code
P1316 IDM Codes Detected
Idles kinda rough & Low on power intermittently
Did a buzz test, 1st test showed Cyl 7 High to low side open
did 2nd and 3rd test, no codes
Truck has 138,500 miles on original injectors.
Is it possible an injector harness or both are bad?
Maybe corrosion in some plugs?
Please let me know what you guys think.
Old 06-10-2009, 04:50 PM
Powerstroke Techie
check your harness under valve cover
