6.0 Rough Cold Start And Idle In Drive - Ford Powerstroke Diesel Forum
post #1 of 17 Old 06-04-2009, 09:30 PM Thread Starter
Ok, I am very sorry but I have been searching and reading all posts I could find on rough idle and cold starts and all that stuff, but my problem seems to be a little different than EGR (Which I have unplugged, no fix & cleaned, no fix) and tested glo plug wires (tested amps on the bundle of wire, found no major difference of amperage).
So, My Problem Is: The 2004 6.0 starts from a "cold start" (coldest is 65 F overnight, I have owned this for 2 weeks) and the engine starts fine, idles fine, put into gear it feels like it misses, take it out of gear it sometimes straightens up, but if you put it back into gear it just "puts" along and shakes the whole truck, if you give it slight pedal it shakes more, and severely lacks power. After a short highway drive it runs fine, for the rest of the day, off and restarted.
It has 119K Miles on it, just changed both filters, ran lucas fuel treatment, changed air filter element, and read codes with a generic code reader, and it was clean.
Help!
Thanks
J
chspyder is offline
post #2 of 17 Old 06-04-2009, 09:33 PM
Quoted: 5 Post(s)
There's something about a cold start reflash floating around here, I think that may help. But maybe atech will spot ur thread and chime in.
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #3 of 17 Old 06-04-2009, 09:38 PM Thread Starter
Man, this is quick help.
Do I have to pay ford to reflash or is it a warranty/recall thing?
chspyder is offline
post #4 of 17 Old 06-04-2009, 09:49 PM
Quoted: 5 Post(s)
well, youre over your warranty, it's up at 5 years or 100k on the ometer, so you'd have to pay. i'm not too keen on the 6.0's but i've seen lots of posts with similar problems being a refalsh fix, so keep bumping your thread up until a tech chimes in. they'll have a green username. good luck bud, let me know if i can help out
ianstew is offline
post #5 of 17 Old 06-05-2009, 06:51 AM Thread Starter
I am going to go by ford later today, thanks!
If anyone has other ideas please let me know.
Just happens I am selling my 7.3 today, maybe I should keep it and sell this 6.Zero!
chspyder is offline
post #6 of 17 Old 06-07-2009, 09:01 AM Thread Starter
Well this is quite interresting, but when its warm no one can tell anything, the tuck tests and runs fine.
Can anyone tell me if I should see a lag of about 2-3 seconds before anything happens when I punch the gas? In my 7.3L there was turbo lag, but almost unnoticeable, this truck (04 Excursion)seems to have fair ammount, my friend with a 04 6.0 f-250 seems to have less than my old 7.3 had.
Just trying to trouble shoot, thanks for the help!
chspyder is offline
post #7 of 17 Old 06-07-2009, 06:00 PM
Quoted: 5 Post(s)
you should have less lag due to the variable vanes in the turbo than your 7.3. I know sometimes the vanes get choked with carbon and don't perform as well, but i'm not sure how to clean it. we always replaced them at work, never fixed em. Did you ask them about the cold start reflash?
ianstew is offline
post #8 of 17 Old 06-07-2009, 06:12 PM
97 golden stroker's Avatar
all of the problems sound like the trubo is getting stuck. you should try to pull it off and cleant it all and put anti sezz on it. had an 04 doing the same at work and cleand the trubo and all the probles were solved. good luck buddy.
97
afe intake
ats intercooler
3in. down pipe to 4in str8
fpr shim
terminator hpop
warm up valve delete
tw 6 position
southbend clutch
Stage ones from Rosewood diesel
SD IDM
d66
12000k hid dual element
thinking real hard about a nozzle upgrade
220k
97 golden stroker is offline
post #9 of 17 Old 06-07-2009, 08:57 PM Thread Starter
I can pull off the turbo and clean, Carb Cleaner? Like the EGR?
And as for the turbo, I would think the turbo sound would be a solid sound if the vanes stuck, and would there be a code?
I do want to note I have no black smoke, but sooty exhaust, like the 7.3l did, not excessive.... I dont think.
Thanks Tons!
chspyder is offline
post #10 of 17 Old 06-07-2009, 09:19 PM
mcflan's Avatar
Feedback Score: 9 reviews
You could run a BG Fuel/Air Induction Service. Depends on where you are, but the link provided has locations of where you can do it and it will help free up air flow. Probably good to do since you're over 100k. The 6.0's, especially early 6.'s start being stubborn in and after 95k. I just got mine not too long ago, but have been around them for 6-7 years with friends and the 03-04's are plagued with Air and Fuel induction issues.
BG Findashop - Fuel/Air Induction Service
It ran me about $340 after tax and a full syntho oil change. Read up about it on the forum, this service has been talked about for a while now. Here's the link to that too:
Fords new carbon cleaning process???
mcflan is offline
