6.0 no start no codes - Ford Powerstroke Diesel Forum
Old 06-04-2009, 12:17 PM
got a call he says truck started running rough and dies crank but no start pulled codes and was none, its a 05 6.0 oil change was due changed oil and filter and fuel filters had new fuel pump about 3000 miles ago wandering if could be injectors no smoke at tail pipe wihile cranking. could all injectors go bad at same time.please help thank you ddh7
Old 06-04-2009, 12:18 PM
FICM maybe?
Old 06-04-2009, 12:24 PM
wouldn't FICM set a code
Old 06-04-2009, 12:58 PM
Chapter Director
it's possible for it to be bad and not set a code may not happend offten but possible. if just the right part of the circuitry gose bad it could completely go out and not have a chance to set a code. casue if it is bad and can' comunicate with the pcm and tell it to set a code then it won't
Old 06-04-2009, 01:14 PM
is there any way to test FICM
thanks for reply ddh7
