Leaking Fuel!!!! Injectors?
Hey i have a 99' f250 with the turbo 7.3ltr powerstroke diesel with 145000 miles and it is constantly dripping diesel from under the turbo down the motor off the oil pan on the axle then to the concrete. WHAT IS GOIN ON i really need to know fast cuz due to bad weather i need this truck.
3 Things.
Your truck is common for fuel leaks after age in 3 places. #1 and most will agree with me is the fuel bowl drain valve. #2 is under the Glow Plug relay bracket, the line can wear a hole in itself on the bracket. #3 is back by the turbo on the same fuel line as under the Glow Plug Relay. On the corner of the turbo pedistal is a clamp that holds the fuel line. It is supposed to protect it but it can eventually wear a hole in it.
Mine's leaking too, same situation?
no.....yours is an OBS truck (old body style)....it has a fuel pump in the valley that the superduties dont have...that will be the most probable cause for your leak...
So just a leaking fuel line? Is it under the turbo? Where at in the valley?
Yours is probably
leaking out the weep hole on the fuel pump.
fuel leak
