Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 06-02-2009, 12:30 PM
workin4my350 workin4my350 is offline
7.3 givin me troubles
Guys, I know I dont post much, just when I have Issues.
Soo here is todays.
driving down my road. truck was doing good, then all of a sudden . the rpms dropped, the truck hessitated ALOT, the engine light came on, and then it would bearly make it up a little hill.
I pulled over, checked the oil. The oil is a little low (at the bottom line). Felt for metal chips, etc. Had a little sparkly look to it (maybe small chips), and some bubbles to the black oil.
What might be the trouble.
Sounded like a pinto not a 7.3.
I had tranny trouble a couple months ago,and went to tranny shop. Got a 1-2 tranny code, had a kink in both tranny cooler hard lines. I got that fixed (many hours of hair pulling), and got a complete flush, with additive. two days later it started slipping. May need that now. So, what do you guys think.
Im leaving to go out of town next week, so might have to hold off on the truck, but need advice.
BAD.
thanks,
Bill
Old 06-02-2009, 12:47 PM
symbols symbols is offline
Nonsense specialist
valve cover harness?
Old 06-02-2009, 01:05 PM
help me with what you meen by valve cover harness? Do they go bad?
Or do I look for hot spots?
Bill
Old 06-02-2009, 01:11 PM
orng1 orng1 is offline
CPS, uvch, oil bubbly might leave air in the hpop which may not fire the injectors...
You need to check the oil more often on these trucks, I never let it get bellow half of where it reads.
Old 06-02-2009, 01:15 PM
Nonsense specialist
The 2 most common problems for our trucks IMO are CPS and valve cover harness. I'm not positive but I think you changed your CPS not to long ago, correct? Our trucks have the injector wiring harness going through the valve cover gasket. It is not uncommon for them to deteriorate and cause the problem you listed.
Old 06-02-2009, 01:20 PM
Under valve cover harness is the first part I ordered for my truck, then the CPS.
Old 06-02-2009, 05:49 PM
I did the CPS last year. Is there a tech article on the valve cover harness?
Thanks for the help guys. Really want to keep the truck, just need reliable trailer hauler.
Bill
Old 06-03-2009, 05:58 AM
Nonsense specialist
I don't think there is. It's really easy just a little time consuming. If you can take off the valve covers and plug a couple things in then you can do this also
Old 06-03-2009, 06:07 AM
got it.
thanks
bill
Old 06-03-2009, 06:39 AM
TexasR.N. TexasR.N. is offline
SOB to Ben
Check the passenger side first. For whatever reason this side seems to go first. Both times on my truck it was passenger side.
It is straight forward as far as removing the valve covers. If they are fried it will be obvious, fried wires and burnt electrical smell. I got my replacement harness from International.
Craig
