Help! Work in 2 hrs, but truck isnt working right - Ford Powerstroke Diesel Forum
Old 06-02-2009, 01:59 AM
Fixed! .Fuel supply issue!!-- It was the fuel pump...
I left my night job, got on the highway, everything swell. I got to pass a car..step on the pedal, nothing, in fact the engine bogs down, i get off the pedal, it goes back up in RPM, but no power being produced...power falls off until engine stops. I pull over.....wait about 8 min, restart the truck, drives like its great........until it dies about 5-6 min later. Kind of like it ran outta fuel.
Help! If a fast fix, I'm happy.
Other issues with truck..occasional misfire when cold. No codes currently aside from p0603 and the p0000 p1000 codes. Yes, it was on looney by DJ but I use it for MPG, not for romping speed...at least not when I'm commuting
Fuel filters are 12-14k miles old, oil changed about 5k ago.
No overheating or shifting issues (aside from no power = no shifting)
thanks for your necessary ideas
Old 06-02-2009, 03:39 AM
nothing huh? crap.
Old 06-02-2009, 03:46 AM
I have no clue what that is. Sorry i couldn't help, but here is a bump for ya.
Old 06-02-2009, 04:28 AM
285,261,190
with 14k on the fuel filters its a possabilitly they are getting clogged???
Old 06-02-2009, 04:51 AM
wriott
Guest
Posts: n/a
i am also thinking fuel filters
Old 06-02-2009, 05:04 AM
Its on the list of things to change, just odd it would strike so suddenly.
Old 06-02-2009, 05:38 AM
Infidel
Don't know squat about 6.0's, but any chance it's fuel pump issue? If not at least it's bump for you.
Craig
Old 06-02-2009, 06:42 AM
+1 on fuel filters. Work truck did the exact same thing. Changed filters and was good to go.
Old 06-02-2009, 06:44 AM
Send a message via AIM to ABoyAndHisToys
Put it back to stock tunes and change the filters. Also drain the water if any. Then see what happens.
Old 06-02-2009, 08:41 AM
Craig
This is exactly what I am afraid of....
Going outside to look at the ol FFs to see if they are nastied up
