7.3 replaced injectors now wont turn over - Ford Powerstroke Diesel Forum
Old 05-31-2009, 07:58 AM
Send a message via AIM to Leading edge props
I have a 2001 f-250 with a 7.3 with 189000 miles Had a check engine light did a buzz test and injector 7 was bad. Went to ford and got the injector and replaced it as well as installed new rings on the other 7 injectors. I had to pull the front rocker on 8 because i just couldn't get the injector out. When I put it all back together I mad sure the push rod seated. Seamed like the rocker was pushing the spring a touch more than the other valves looked. Turned it over it turned over maybe 4 time and then a sound like taking a hammer to a I-beam. I tried to turn the crank manually and cant get it past 8 either way I turn it. Been told maybe bad valve or hydro locked any ideas? I am going to take out the glow plug on 8 this morning and see if it passes threw when I manually turn the crank. Any ideas would be great full.
Old 05-31-2009, 02:51 PM
sounds like a bunch of oil in the cylinders pull the glow plugs crank it over with a bar a few times
Old 05-31-2009, 03:47 PM
update!!!!
ok so i got it to turn over the valve is fine. It is totally running rough and blowing tons of white smoke is this from the injector job will it clear out?
Old 05-31-2009, 05:19 PM
ITS RUNNING
Thanks CJ its running and the smoke is almost gone its runs way better than even before the injector went out. Awsome
Old 06-09-2009, 11:59 AM
Send a message via AIM to BlackSmoke&BuckinHorses
Just for future reference... When you pull an injector, all the fuel and oil from the rails has to go somewhere. That somewhere is into the cyl. Find some way to suck out the cyls. to avoid damage. Not a necessity but it keeps you from having the problem that you ran into
