blowin lots of white smoke - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-28-2009, 06:17 AM Thread Starter
heres the story. i had to make a run out of town for work. about a 700 mile round trip run. just into my trip my service engine light came on. i pulled into a truck stop to check things out. i noticed my coolant resevoir was low so i toped it off. later on the light went off. i came home yesterday with no problems, no lights on the dash, the truck performed fine. this morning i went out side and started my truck to let her warm up a bit. after about 10 min i went out to leave for work and noticed was truck was puffing white smoke. i took it down the street and it started blowing large amounts of white smoke, mosquito truck style. i know white smoke means i'm buring coolant. my question is typically where is the problem? head gasket, something in the turbo? the truck's motor is stock as far as i know and has abot 78K on it. it is in route on a flat bed to the dealer now.
smboudreaux is offline
post #2 of 8 Old 05-31-2009, 08:31 PM
gmsmith36's Avatar
Not coolant, timing, low fuel pressure, low compression. Most likely it is just a IPR or HPOP. Could be a injector.
gmsmith36 is offline
post #3 of 8 Old 05-31-2009, 09:29 PM
OregonStroker's Avatar
head gasket. if the truck runs good, and idles smooth but blows white smoke. its a head gasket. The only reason I jump to this conclusion is because of the coolant loss.
Built engine, rods, pushrods, cam, springs. Meth, turbo, injectors, fuel system, oil system. 3 disk billet, billet shafts built trans, 6.0 IC, exhaust, intake. Latter bars, gears, system, tint, HIDs. You know the typical stuff to make a 7.3 get out of its own way...
dont brake.
OregonStroker is offline
post #4 of 8 Old 05-31-2009, 09:47 PM
Quoted: 5 Post(s)
EGR maybe? can't those make you blow white smoke.... or head gasket......
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #5 of 8 Old 06-01-2009, 03:23 AM Thread Starter
Originally Posted by ianstew View Post
EGR maybe?
bingo. i got it back saturday. dealer said it was the egr cooler and the egr valve was going bad so they replaced both all under warranty.
the only problem is, it looks like the previous owner had some sort a flash tune on it. apparently the dealer whipped that off and put it back to stock. it runs like a big ole stock turd now
post #6 of 8 Old 06-01-2009, 04:13 AM
ADMIN AND TECH
SCUFFY828's Avatar
head gaskets do not cause white smoke , i know this truck already been fixed but , a just for the record thing for other members , egr cooler is cause of white smoke or bad injector or even turbo, but with coolant loss , egr cooler in this case , if they didnt replace oil cooler you will probably be goin back before long
ITS STOCK
SCUFFY828 is offline
post #7 of 8 Old 06-01-2009, 04:20 AM
wriott
Guest
Posts: n/a
Quoted: Post(s)
yes you will... happended to me.... more than once...
post #8 of 8 Old 06-01-2009, 11:08 AM Thread Starter
i'll have to look at the service ticket. they may have replaced that also. they list was pretty long
