i thought i was helping the problem - Ford Powerstroke Diesel Forum
Old 05-17-2009, 04:35 PM
ok my truck since i got it took forever to start. cure. replaced the 6 glow plugs that were junk in it and i pulled all the injectors to see if the o rings looked good. i put it all back together and i cant even get it to start. wtf? im starting to dislike diesels.
Old 05-17-2009, 04:47 PM
If it aint a CAT itsa DOG
I am assuming it will turn over but no fire? If so you might have air in the fuel lines from taking out the injectors.
Old 05-17-2009, 04:55 PM
I assume you replaced the injector orings while the injectors were out? It will crank for a long time before she fires, dont get discouraged after a short time. Is there fuel in the filter housing? Keep on cranking it, sometimes they take awhile.
Old 05-18-2009, 06:49 PM
i didnt look to see if there was fuel in the bowl. how much pressure should be at the shrader valve with key on?
