7.3 Ford Diesel struck by lightning - Ford Powerstroke Diesel Forum
Old 05-17-2009, 01:43 PM
Hit by lightning last night. Driving through really bad storm. Felt a jolt, bright in cab, then a few seconds later check engine light came on, then miss fireing. When I came to stop at light 10 min later engine cut off. It started back up, I went about a mile down the road, pulled over, cut truck off, checked fluids, started back up, check engine light off and after driving again for a few seconds it came back on. The engine started missing again. Took it to Advance to check codes and the code reader would not register that it was plugged into truck. Kept saying "plug into vehicle to run test". Tried cleaning terminals and re-plugging code reader and it kept saying the same thing. I noticed air bag Off light came on. Other than that everything else seemed fine. Anyone had any experience with this or has any idea what the damage might be? Will insurance help pay for damage? or am I SCREWED!! Help appreciated!
Old 05-17-2009, 01:51 PM
wow man I have no answers for ya but I have to say thats one of the coolest things ive ever heard! hahaha Good luck explaining that to your insurance company.....Hope everything works out for ya though. that sucks
never had experience with this, but advanced auto and and places like that dont read our trucks, they can only erase codes. sounds like you have some fried wires. You have to get an obII code reader on your truck. sorry about your luck bud. i think dealerships charge $75 to read codes but not sure.
Old 05-17-2009, 02:05 PM
I checked again with the advance I took the truck to and they confirmed that their code reader the OBD2 would read the codes... So I'm kind of confused about that? The truck is still sitting there because I could not drive it 35 miles home. I need to check it out further today. At least it is not raining...
Old 05-17-2009, 02:18 PM
it will plug in and "read" but you they have CHEAP junk readers that wont tell you anything. sorry about your luck bud but you need to take it to a dealership or a friend with a real reader. You could also start looking for fried wires on your truck. trust me though. advanced auto scanner= junk and wont work on our powerstrokes.
Old 05-17-2009, 05:24 PM
Check the fuse for the OBD2 link. If it is the same as my mustang, it will be the same fuse as the cig lighter. It may be fried. Does your cig lighter or power point work? The owners manual will tell you which fuse. If it did blow that fuse, you may have computer damage.
Old 05-19-2009, 05:18 PM
I worked in a service dept at the local dealership for a lil while once. We had an explorer come in once that was hit by lightning. Hit it on the antenna. It wasn't running when it was brought in, after replacing EVERY single module and computer in the thing, still nothing.... it fried like the entire wire harness. Yours doesn't saound NEARLY as bad but, I would Definitely take it to a dealer... keep us posted
Old 05-19-2009, 05:22 PM
WOW, that sucks, hope its nothing like loosing a chassis ground, you could be replacing alot of parts. your ins. co. should cover it if its full coverage, good luck.
Old 05-19-2009, 07:59 PM
^^^ What he said. I think the OBD port not working is a coincidence. Check your power point/cig lighter for power, I bet you won't find any. Once you get the fuse replaced, then go get the codes read. The Advance Auto parts reader might not be great, but it will at least give you memory codes.
Old 05-20-2009, 10:33 AM
your gonna have to take it to the dealer to get it fixed. I don't know if your insurance will cover an "act of god" or not good luck. More than likely several of the modules are damaged along with some of the wiring. keep us posted
