how do you pull an injector out?
ok i took the valve cover off, then i took the 4 torx bolts off and the black little box on top of the injenctor comes off. then i took the two 8mm bolts out and the one allen bolt out and i tried pulling it out and it wont budge. what else is envolved in taking the injector out?
you have to pry it out.
a small pry bar and steady pressure. check out maintains video in the tech files
Yeppers a small prybar will pop it right out. Reason being the O-rings seal that thing in there pretty tight.
I prefer a long bolt threaded into the hole where the oil deflector screw (allen bolt) came out of. It will draw the injector right out without any prying. Prying is acceptable, just pry against something that isn't going to break..
Oh, BTW, you don't need to take the 4 torqs bolts out of the square top piece, nor do you have to take out the inboard 8mm bolt out. Only the outboard 8mm bolt has to come out. Then you slide the fastening girdle towards the engine valley, and it will disengage from the inboard bolt. |
where are the two bolts that drain the oil out of the head so when i pull the injectors the oil doesnt flow in? i got the injector out with a little more prying, i do like the idea of putting a bolt in to push it out instead though
where can i get a complete o ring kit for all of the injectors?
the plugs are located between the front and back two injectors on each head. you can get the orings from alot of places. the best prices i found was from Diesel Care and Performance.
