HELP WITH OIL FILTER - Ford Powerstroke Diesel Forum
Old 05-12-2009, 06:13 PM
I just bought an 05 6.0L. Tonight I started changing the oil, but when I took the filter out I think someone had a WIX filter in it. I purchased the fl2016 motorcraft filter and it looks different than the WIX. The wix filter had a plactic peice setting on top of the filter, but it looks like the motorcraft filter has this built on. I wanted to know if I'm supose to use this peice or discard it. Does anyone have a diagram of how this goes together? I'm dead in the water until I find out how this goes together.
Thanks,
Jim
Old 05-12-2009, 06:18 PM
Rice Hunter
That's what get most in trouble! If you keep that plastic piece which usually stays in the top of the filter cap,,,,,,it will cause your filter to crush or filter cap to crack. Stick to Motorcraft!!
Old 05-12-2009, 06:20 PM
Rice Hunter
If you try and screw the filter cap down with that extra plastic piece.....YOU WILL NOTICE HOW TIGHT THE CAP GETS!!!!!
Old 05-12-2009, 06:28 PM
Rice Hunter
This may help some
http://www.backglass.org/duncan/ps60...l/ps60_069.jpg
Old 05-12-2009, 06:40 PM
Rice Hunter
HERE YA GO
http://www.youtube.com/watch?v=E2ynQ1E6H8U
Old 05-12-2009, 08:36 PM
Thanks for the help guys. I left it out and it seem to go together good. I'll only use motorcraft products. That's all I ever used on my 7.3. I guess I don't have an excuss to stay at home tomorrow since I got back together tonight.
Thanks again for the quick response,
Jim
